eagle rod info
Old Dec 23, 2005 | 11:23 AM
gotboostedvr6's Avatar
Default eagle rod info
sorry about the noob question but on a eagle rod, if a 13mm sockett fits on the rod bolt hex head what size is the stud/bolt ?
Old Dec 24, 2005 | 12:14 PM
Default Re: eagle rod info (gotboostedvr6)
need a hand here peeps
Old Dec 24, 2005 | 05:47 PM
no help?
Old Dec 24, 2005 | 07:32 PM
non-VTEC's Avatar
what engine are those eagle rods for?
13mm socket sounds really strange......eagle uses either 3/8" ot 7/16" ARP bolt heads for honda rods.
3/8" head = 5/16" bolt
7/16" head = 3/8" bolt
unless you have some custom rods or something you have to double check which bolts you got.......try using standard sockets rather than metric.
Old Dec 25, 2005 | 08:16 PM
nickromeo's Avatar
isnt 13mm close to 1/2 inch?
Old Dec 26, 2005 | 05:08 AM
Default Re: eagle rod info (nickromeo)
yes but thats the bolt size not the stud size
Old Dec 26, 2005 | 06:04 AM
zman's Avatar
aren't they 12pt bolts as well?
Old Dec 26, 2005 | 06:20 AM
I don't think the guy who is relaying the info to me knows what he is doing
im gonna have to chk for myself ill keep you guys posted
Old Dec 27, 2005 | 11:46 AM
if there is a way to tell bolt size by pics
http://i24.photobucket.com/alb...0.jpg
and another
http://i24.photobucket.com/alb...6.jpg
Old Dec 27, 2005 | 12:43 PM
non-VTEC's Avatar
maybe your confusing the main studs with the rod bolts..........
Old Dec 27, 2005 | 02:00 PM
Default Re: eagle rod info (non-VTEC)
the info was given to me i never touched the block
Old Dec 27, 2005 | 05:03 PM
non-VTEC's Avatar
I'm willing to bet money that the guy gave you the wrong info. or maybe you misunderstood him.
the main studs are 1/2" bolt heads (close to 13mm) and the rod bolts are either 3/8" heads or 7/16" heads.
Old Dec 29, 2005 | 05:06 AM
boostinh22
Guest
Posts: n/a
i'm pretty sure all the 2000 series bolts are 3/8" heads.
Old Dec 29, 2005 | 05:38 AM
not to second guess but is there any one here to confirm this
Old Dec 29, 2005 | 07:00 AM
boostinh22
Guest
Posts: n/a
if you're talking about the size of the bolt head that i posted, look on the eagle website.
here's a link
http://www.eaglerod.com/produc....html
Old Dec 29, 2005 | 07:41 AM
Default Re: eagle rod info (jerseykid609)
jon:
i just talked to the guy and he said they are the 7/16" i told him to send me a pic with the wrench on it to prove it but if it is 7/16 i think im gonna buy it
Old Dec 29, 2005 | 04:10 PM
NJIN BUILDR's Avatar
The 5/16" bolts (with 3/8' head) are the older bolts.The 3/8" bolts (with the 7/16" head) are the newer,stronger bolts.
Glenn
Old Dec 30, 2005 | 05:27 AM
Default Re: eagle rod info (NJIN BUILDR)
thank you guys for the info
CustomX113
Nov 12, 2006 05:53 PM
kidd_drastic
Jan 28, 2006 10:04 AM
genop
Mar 30, 2004 07:15 AM
PM-Performance
Feb 20, 2004 04:08 AM
blufke
Feb 19, 2004 08:05 AM
