Maybe a dumb question about Honda engine building...
Old Jan 12, 2006 | 06:43 AM
scheistermeister's Avatar
Default Maybe a dumb question about Honda engine building...
im personally not too familiar with hondas and had some questions about building Honda motors. first one may be a little dumb, but im not entirely sure since ive only delt with chevys and rotaries.
when you go with new internals do you have to have them balanced? i would think so but not sure. and are they internally or externally balanced?
next question is when boosting a B18 at what levels do you need to have the engine sleeved? about how much does it run to have that done?
just sorta curious, thanks.
Old Jan 12, 2006 | 08:24 AM
N2O's Avatar
N2O
Default Re: Maybe a dumb question about Honda engine building... (scheistermeister)
I would always recommend have the internals balanced. you can rev the **** out of a B18 so you want to make sure that everything is balanced. I am not sure what you mean by internal or externally balanced but the is no balance shaft on a B18 so everything is balanced by the particular weight of the parts.
As for the amount of boost a B18 will handle before getting sleeved I have Seen people run as much a 14 lbs and not have to much problem however the motor didn't last that long. if you are going to go throw the process of balancing the motor I would have it sleeved. It will save you alot of problems and money in the future. Plus a good sleeved block will last you a long time. Its kinda like building a house on sand or on a good cement foundation. Have a reputable shop do the at least the sleeve work.
Old Jan 12, 2006 | 08:35 AM
Default Re: Maybe a dumb question about Honda engine building... (N2O)
im in cincinnati ohio.
i have a machine shop that has done great work for me in the past, but that was on chevy motors and i dont know if he knows much about hondas.
oh if its balanced by the weight of the parts its internally balanced then.
do you have a rough estament of what sleeving costs?
Old Jan 12, 2006 | 08:47 AM
N2O's Avatar
N2O
I am sure your machine shop does awesome work but sleeving a Honda block the right way is a very precise procedure. There is alot of setup that goes into machine the block to accept the sleeves and keep them from moving. I highly recommend having Justice racing In Maryland do the work for you. They specialize in Honda's and small engine and do some of the best work I have ever seen. The cost of shipping a block ground isnt that expensive. Give them a call and ask for Jim he is the owner.
http://www.justiceracingengines.com/
301-624-1000
moubrco
30
Oct 27, 2012 06:32 AM
smithenhiven
Dec 27, 2006 09:22 AM
mtropolis
Nov 15, 2004 09:57 AM
RotiEatter
Feb 2, 2003 05:40 PM
BOO YEAH
Aug 9, 2001 09:14 PM
