many problems all at once!
Old Aug 11, 2003 | 05:38 PM
chictunner97ex's Avatar
Default many problems all at once!
ok just today i found that my car has burned through about 2 1/2 quarts of oil in 5 days. i am confused though it doesn't have any oil leak, and it is not smoking out the exhaust, and it is running stronger then ever! the other thing i noticed is that the oil dipstick smells like fuel. is it time to look for a new engine? oh ya it has 126,500 miles on it. i found this out today along with a torn CV boot, and a torn ball joint, both on the driver side! anyway what i need to know is what is going on with my motor? and why does it seem like you replace one thing and another goes out, or more then one thing goes out at once!!!
Old Aug 12, 2003 | 04:34 AM
dip-set's Avatar
Default Re: many problems all at once! (chictunner97ex)
welcome to the club ..."if it aint one thing its another"
Old Aug 12, 2003 | 08:46 AM
Blaze45's Avatar
Brrraaaap!
Default Re: many problems all at once! (teg-your-it)
Dude if you smell gas in your oil you got some serious issues... Check your compression and I would take the head off to get a better look @ things... Course that would be quite a hassle...
hope you figure it out...
Blaze
Old Aug 12, 2003 | 05:07 PM
Default Re: many problems all at once! (Blaze45)
i just got done doing head work on this car about three weeks ago. it has a new head gaskett, and everything went well. i will be cheking the compression today. thanks for the replies, keep them coming, gloria
Old Aug 12, 2003 | 05:11 PM
Kamin's Avatar
Gloria i would actually step it up to a leakdown test.
Old Aug 13, 2003 | 12:04 PM
1_bad_EF's Avatar
hmmmmmmmmmm do a leakdown and compression test. ps keep me posted and feel free to im me again.
Old Aug 13, 2003 | 03:39 PM
ninjaMONKEY
Guest
Posts: n/a
Default Re: many problems all at once! (1_bad_EF)
If there is fuel in your oil then say good by to all your seals. Did they replace your valve seals when you got your headwork done?
Old Aug 15, 2003 | 03:45 PM
Default Re: many problems all at once! (ninjaMONKEY)
hey guys i did the head work, and i made sure all my seals were fine, including the oil piston rings. it just started to get stronger, but it always had a light smell of fuel on the dipstick. but i will keep you guys posted on what i find out, and thank you for all the replies!!! gloria
Old Aug 15, 2003 | 03:50 PM
turbochic's Avatar
dayam, that sux!!
so fuel smell in oil means????????
valve seals?
wanna know how it turns out
Old Aug 15, 2003 | 05:14 PM
Mohudsolo's Avatar
Default Re: many problems all at once! (fmaxturbochic)
Fuel smell sounds to me like leaking injectors. Even with blowby from seals or rings, it would be burnt fuel, not raw. Raw fuel is either running really rich or injectors leaking. That could also rinse the oil film off the cylinder walls and make it burn oil easier because of the gas diluting it.
With the injectors removed and attached to the fuel rail, pressurize the system and see if gas drips from the injectors. Having them cleaned and rebuilt is the best thing to do. RC along with other places do them for $35-50 each.
Old Aug 15, 2003 | 07:30 PM
SpydermanGS-T's Avatar
Default Re: many problems all at once! (Mohudsolo)
We are watching the oil level for the next few days.. Car runs strong and the smell on the dip stick is very minimal...As far as seals "I really don't think so!" But we are gonna do the leakdown and compression test to be sure.
Old Aug 17, 2003 | 10:42 AM
Default Re: many problems all at once! (SpydermanGS-T)
but i think mohudsolo is right, i am definatly running too rich, my plugs are so black and cruded up with black crud! but thanks guys for the replies, and rest assured the car is going to the dyno to fine tune it this week, so according to my tunner, this should take care of the problem. also i posted a thread a while back on misfire codes that i had, and i found out that i just didn't clear the ECU completely to rid the memory of the codes to begin with. so the codes are all gone now. thanks for everything guys!!! gloria
sambam27
Nov 28, 2004 07:36 AM
97TegraLS
22
Sep 7, 2004 04:24 AM
thehondaguru
Jun 9, 2004 06:09 PM
ThisLittleSleepeR
Jun 7, 2004 04:30 AM
H23A1LUDE
May 7, 2003 12:59 PM
