manual trans to auto block, is it basicly a bolt on job?
Old Aug 11, 2003 | 09:29 PM
roydogg's Avatar
Default manual trans to auto block, is it basicly a bolt on job?
Okay, I own a 94ls with a manual trans and just bought a 94 ls automatic motor cuzz it has lower miles than my existing motor and my rings are gone so I have to rebuild.
Is it as easy as it seems, pull my motor out and take my trans and just bolt it on the new block? When thats done just put the motor back in? Or do I have to do some more work to get it runnin right?
Thanks,
Roy
Old Aug 11, 2003 | 10:12 PM
salbaje's Avatar
Default Re: manual trans to auto block, is it basicly a bolt on job? (roydogg)
yes transfer your clutch,flywheel and tranny
Old Aug 11, 2003 | 10:25 PM
roydogg's Avatar
Default Re: manual trans to auto block, is it basicly a bolt on job? (salbaje)
Thanks, thats what I thought . As long as they are or have the same block # it's all interchangable. How bout the camshafts specs is there a difference between the 2motors?
Old Aug 12, 2003 | 07:14 AM
91tegrals's Avatar
with b series motors there is no such thing as and auto or manual motor the will bolt to each one...
Old Aug 12, 2003 | 08:06 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje &raquo;</TD></TR><TR><TD CLASS="quote">yes transfer your clutch,flywheel and tranny</TD></TR></TABLE>
Make sure you use the longer bolts to attach your flywheel to the crankshaft. Crankshafts are the same but the flexplate (for auto) is thinner than a flywheel.
Old Aug 12, 2003 | 08:40 AM
Blaze45's Avatar
Brrraaaap!
Default Re: manual trans to auto block, is it basicly a bolt on job? (JimBlake)
For sure on the flywheel bolts.... Sucked for a friend that didnt have em and was in the middle of the swap....
Blaze
Old Aug 12, 2003 | 08:47 AM
irev210's Avatar
Default Re: manual trans to auto block, is it basicly a bolt on job? (Blaze45)
just remember when ur taking off the flex plate that u lift up the entire longblock w/ tranny on it like on a cherry picker, then unbolt the very bottom bolts that you cant reach when the engine is on the ground. AFter that take off the black lower tranny cover that covers up the flex plate. After that, just continue to unbolt all the 10mm bolts that hold the flex plate onto the torque converter. If you dont do that, the auto tranny aint commin off.
good luck
peace
Old Aug 12, 2003 | 09:07 AM
roydogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
I hope my mechanics knows that. I'll have to inform him about that. Thanks,anything else?
Old Aug 12, 2003 | 09:08 AM
roydogg's Avatar
Default Re: manual trans to auto block, is it basicly a bolt on job? (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">just remember when ur taking off the flex plate that u lift up the entire longblock w/ tranny on it like on a cherry picker, then unbolt the very bottom bolts that you cant reach when the engine is on the ground. AFter that take off the black lower tranny cover that covers up the flex plate. After that, just continue to unbolt all the 10mm bolts that hold the flex plate onto the torque converter. If you dont do that, the auto tranny aint commin off.
good luck
peace
The auto tranny is already off the block and is waiting for my tranny as soon as I drop my car off.
Old Aug 12, 2003 | 09:28 AM
roydogg's Avatar
Default Re: (91tegrals)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tegrals &raquo;</TD></TR><TR><TD CLASS="quote">with b series motors there is no such thing as and auto or manual motor the will bolt to each one...</TD></TR></TABLE>
Please explain why not?
nihad
Feb 22, 2007 07:24 PM
beelzebub
Jan 11, 2007 10:19 AM
RockLee`
15
Aug 25, 2005 05:23 PM
BigLoadChoakHard
Jul 16, 2003 10:01 PM
