major studder on my b18c1
Old Aug 7, 2003 | 06:20 PM
FreshSol's Avatar
Default major studder on my b18c1
When my car is cold the idol is hi .. ok fine .. but the idol studders from 2500 to 1500 and bounces in between untill i start to drive .. when at a stand still it will continue the studder .. and after my car is warm if i hit the gas to open the throttle 2 to 5% the car will studder the same way ... whats goin on????
Old Aug 7, 2003 | 06:29 PM
quik1's Avatar
Default Re: major studder on my b18c1 (FreshSol)
Sounds like the idle air control valve has gone bad.
Old Aug 7, 2003 | 07:01 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FreshSol &raquo;</TD></TR><TR><TD CLASS="quote">When my car is cold the idol is hi .. ok fine .. but the idol studders from 2500 to 1500 and bounces in between untill i start to drive .. when at a stand still it will continue the studder .. and after my car is warm if i hit the gas to open the throttle 2 to 5% the car will studder the same way ... whats goin on???? </TD></TR></TABLE>
sound to me vaccuum leak. get a can of brake clean and spray around the intake manifold area and all vaccuum hoses to comfirm this.
Old Aug 8, 2003 | 08:08 PM
FreshSol's Avatar
Default Re: major studder on my b18c1 (HONDADNA)
i checked my major hoses and i can see a hole in one but the hose is conected to the side of the fuel rail .. didnt do the brake fluid check .. im gettin on that .. thanx
Old Aug 9, 2003 | 08:01 PM
Xsi's Avatar
Xsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FreshSol &raquo;</TD></TR><TR><TD CLASS="quote">i checked my major hoses and i can see a hole in one but the hose is conected to the side of the fuel rail .. didnt do the brake fluid check .. im gettin on that .. thanx</TD></TR></TABLE>
You have a hole in a fuel line? thats never good....
umair
Mar 2, 2009 05:08 PM
do_0b
Dec 30, 2006 10:39 PM
eg_civic209
Dec 1, 2006 06:11 AM
ans
Jan 1, 2006 05:53 PM
quik1
Dec 19, 2003 03:32 PM
