i just installed my koni yellows and h&r race springs. i have crazy wheel hop in first gear. what happened? what do i need to do to fix this?
kind of obscure question, but yeah.
i forgot to screw in the shock collar bolt (the top one that keeps the shock collar clamped, not the bottom long one), so would that affect anything?
on a side note, how long does it take these springs to settle? i still have wheel gap dammit!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu »</TD></TR><TR><TD CLASS="quote">i forgot to screw in the shock collar bolt (the top one that keeps the shock collar clamped, not the bottom long one), so would that affect anything?</TD></TR></TABLE>
Fix it right and see what happens
ahaha. i cant find the bolt. im glad it is a 14mm, because i have plenty of those lying around and that nut from the stock shock will work just fine.
huh, it's a 10mm bolt (10 x 1.25 i believe). it does not use a nut, the other side of the fork is threaded. I can't believe you drove it with no bolts!
