lsvtec turbo
ok guys, i have a ls turbo setup, and i also have a gsr head i am planning to build the head and put it on the curent setup i have.
this is what i have planned so far
obd1 gsr head
port and polished
skunk2 intake mani
skunk2 cam gears
new honda valves
honda gsr cams
dual valve springs--not sure what brand yet
retainers not sure what brand yet
thick copper head gasket
the block
has 20xxx on it
block guard
honda ls rods
honda ls pistons
honda gsr oil pump
please advise on recommendations, suggetions to make this setup better
obd1 gsr head
port and polished
skunk2 intake mani
skunk2 cam gears
new honda valves
honda gsr cams
the block
has 20xxx on it
block guard
honda ls rods
honda ls pistons
honda gsr oil pump
thats nice, first what power are you trying to get? how many psi?
for a mild boost setup+ the cams that you have you wont need anything better than lets say itr outer springs and portflow(or whatever else) inners.
i will be running 6psi whenever the car is driven, and 12psi for high boost,
am not really concerned with power watever power it make will be more than my curent setup
a few guys on anothr board was suggesting that i change the ls pistons and rods......
do you think that is necessary for only 12psi?
i have been running 12psi on my other 2 turbo ls setups since may and no problems so far, what do you think?
