LSVtec timing belt problem HELP!!
Old Dec 21, 2012 | 04:41 PM
whoiszdizguy's Avatar
Icon2 LSVtec timing belt problem HELP!!
whats going on ht, im in the process of putting my lsv together and ran across this problem,if you guys can please help me out mayb one of you had this problem. well, im using a :
2001 ls block
2001 ls water pump 19 teeth nonvtec
2001 ls oil pump 17 teeth nonvtec
2000 gsr head
ls timing belt 125 teeth
and golden eagle cam gears. "if that matters"
well the problem is that the timing belt is to short! looks like its like 4-5 teeth to short. the tenstioner is loose.and moves freely and its still to short,
i was told. if you use a ls water pump you have to use a ls timing belt.
should i try a gsr timing belt? would that throw it off timing or anything along thos lines being that the gsr timing belt has 126 teeth n uses a water pump with 22 teeth?
all feedback welcomed, trying to get this done. thnks H.T
Old Dec 21, 2012 | 06:41 PM
Na-Spirit's Avatar
Default Re: LSVtec timing belt problem HELP!!
I use a 22 teeth water pump with gsr timing belt and itr oil pump.
All the info you need is in here.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
Old Dec 24, 2012 | 05:10 AM
kyden's Avatar
you sure you don't have a b16 timing belt?
Old Mar 6, 2013 | 10:16 PM
Alex_fl05's Avatar
Hey I have the same problem.
The timing belt I never changed on B18B1. I just replaced the head with B16 head and the timing belt is too short by a couple of teeth.
I know the water pump and timing belt are the same because it was all good when the b18 head was on. Tensioner works fine too.
Any ideas?
I'll change timing belt and/or pulley as soon as I get crank wrench, if I don't fix problem.
Old Mar 9, 2013 | 09:20 PM
Alex_fl05's Avatar
Bump
Old Mar 10, 2013 | 04:11 PM
civickiller's Avatar
when i did my lsv, i used all my stuff and just changed the head,ls wp and lstiming belt then after 30k i swapped to a gsr wp and a gsr timing belt so i know they both fit
Old Mar 10, 2013 | 08:48 PM
ThePunisherPnc's Avatar
u need a vtec water pump and a vtec oil pump with a gsr timing belt...
Old Mar 12, 2013 | 04:55 PM
Alex_fl05's Avatar
Well I'm sure it has a ls water pump and timing belt. The funny thing is, when it had the b18b1 head on, everything fit well.
With my b16a head, it didn't fit. Too short.
I put my LS timing belt from my old engine and it fit. Weird... but works
Old Mar 18, 2013 | 01:31 AM
wasup guys. im late i know. but igot the problem fixed. i couldnt find a regular oem blk tomong belt to fit. so i orderd a blue Gate racing timing belt for Ls and believe it or not it fit perfect!
rick_rabies
Apr 1, 2009 12:59 PM
B18 CYA
May 11, 2005 03:11 PM
gsrvtechatch93
Jun 5, 2004 09:13 PM
Rod.
May 30, 2004 05:51 AM
BoOsTiN Dc2
Feb 7, 2004 04:49 AM
