lsvtec questions....wanna do it right the first time
Old Mar 16, 2003 | 07:21 PM
delslow94's Avatar
Default lsvtec questions....wanna do it right the first time
will a b16 oil pump work for the setup? then what oil pan/pickup/windage tray should i use for the motor? and lastly how do i make a b18c girdle fit the crank/block and can i use gsr main caps on this setup or do i need to use ls and machine them? thanks guys for all your help...like i said i want to do it right the first time to make it as reliable as possible. this will be a fully built motor so that too will help with it.
edit: what water pump should i use also. thanks
[Modified by delslow94, 8:21 PM 3/16/2003]
Old Mar 16, 2003 | 07:25 PM
ls_vtec_b18a1's Avatar
Default Re: lsvtec questions....wanna do it right the first time (delslow94)
a b16 oil pump will work fine and u need to use a vtec water pump with a vtec timing belt.
Old Mar 16, 2003 | 07:26 PM
delslow94's Avatar
Default Re: lsvtec questions....wanna do it right the first time (ls_vtec_b18a1)
ok excellent what about the windage tray/ oil pan/pickup and the girdle. does anyone know about them? no sites that i can find will say. thanks
Old Mar 16, 2003 | 07:53 PM
delslow94's Avatar
bump for the morning
Old Mar 16, 2003 | 08:30 PM
3rdGteg's Avatar
you don't NEED a vtec water pump, u can use an ls water pump, b16 oil pump and still be able to use an ls timing belt.....cheaper in my opinion You can just also use the ls pan, windage, etc.
D0-Kid
Oct 18, 2007 02:29 PM
bens_redeg
Jul 10, 2004 07:11 AM
jDMJeRk
Jan 27, 2004 10:45 AM
Hondasaurs
Feb 25, 2003 04:20 PM
X2BOARD
Apr 16, 2002 12:26 PM
