LSD question for my B16
Old Jun 28, 2007 | 02:00 AM
atlplayer4life90's Avatar
Default LSD question for my B16
ok i have a b16 tranny and i really want to put LSD in it so could some one help me with a list of parts that i need or a complete kit that i can buy and put in and what brands are good thanks for any help
is OBX really good or a waste of money
Old Jun 28, 2007 | 09:31 AM
93widebodyeghatch's Avatar
theres a really good LSD setup made by a company called Phantomgrip i believe http://www.phantomgrip.com/ its not your typical looking lsd but i was told this was the best LSD to get so i bought it and got it installed but havent been able to test it out since my motor is still getting machined..
Old Jun 28, 2007 | 07:18 PM
slowcivic2k's Avatar
Default Re: LSD question for my B16 (atlplayer4life90)
No parts outright should be needed, If your carrier bearings are in good shape transfer them from the factory differential to the OBX, along with the ring gear, speedo gear, and reshim the differential. It would also be a good time to give your tranny a once over to see how things are going on the inside of the case.
Remember the ring gear bolts are a left hand thread, right to loosen, left to tighten.
Old Jun 28, 2007 | 11:58 PM
Default Re: LSD question for my B16 (slowcivic2k)
thanks for the info why do some people say OBX is junk or are they better now
Old Jun 29, 2007 | 07:09 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: (93widebodyeghatch)
Phantom Slip, works so shitty you never knew it was there
OBX LSD, new diff bearings, speedo drove gear off your old diff, might as well replace the input shaft bearing and all 4 seals, only a extra $50 in parts. It like replacing the water pump when you do a timing belt.
I've installed 16 OBX's now, never a complaint.
Old Jun 29, 2007 | 08:12 PM
Default Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">Phantom Slip, works so shitty you never knew it was there </TD></TR></TABLE>
XD
Old Jun 29, 2007 | 11:03 PM
Mista Bone's Avatar
D Tranny Guru
Cliff Notes, they tried to sue me over that comment
Till I mentioned patent enfringment
Old Jun 30, 2007 | 01:32 PM
hey thanks alot mista bone im ordering mine today
Old Jul 1, 2007 | 04:10 PM
hey mista bone where can i get those parts from and would u know any part numbers thanks man and what 4 seals are u talking about
Old Jul 2, 2007 | 01:36 PM
Mista Bone's Avatar
D Tranny Guru
Honda/Acura dealership
Old Jul 2, 2007 | 10:16 PM
ok what all four seals are u talking about
Old Jul 3, 2007 | 12:26 AM
Mista Bone's Avatar
D Tranny Guru
if you can't find the four rubber seals, you have no business messing with a OBX.
Comma ,
Period .
Ti3d in
Transmission & Drivetrain
Mar 16, 2009 02:46 PM
JDM_rolex
Aug 8, 2007 12:27 PM
ZenDynasty
Mar 27, 2005 09:19 PM
