LSD
Old Jul 9, 2006 | 04:31 PM
JDMbull's Avatar
Default LSD
Well I need some help I want to figure out what type of transmission I have
It says S80 But how do I knnow its LSD?
Old Jul 9, 2006 | 10:06 PM
ImportMotorSpec's Avatar
Default Re: LSD (JDMbullshit)
Look through where the axles go through and if you see a bar, its non lsd. If there is no bar through the middle, it is lsd. So pray for no bar.
Old Jul 10, 2006 | 03:58 PM
spooledhonda's Avatar
* B A N N E D *
if it's in the car already i know a great way to figur it out. rev the motor to like 5000RPMs and let the clutch go really fast and if theres stripS you have LSD if not your gona have to rotate yout tiers alot
Old Jul 10, 2006 | 04:03 PM
TwoRedEGgs's Avatar
Default Re: (spooledhonda)
If there is no additional number info on the tranny, then the only way to be 100% sure is to pull out the axles and look at the diff itself. As stated by another member already if you can see clearly through the diff (no bar) then it is an LSD Diff.
Old Jul 10, 2006 | 07:09 PM
JDMbull's Avatar
I ll check that!
1sikhatch
Aug 11, 2010 09:34 PM
jazmie
Transmission & Drivetrain
Feb 1, 2010 10:20 PM
RanCRX
Aug 4, 2008 11:26 AM
chameleon
Apr 14, 2002 05:11 PM
d mafia
Jan 18, 2002 09:52 PM
