ls vtec turbo problems
Old Apr 21, 2010 | 06:34 PM
lowlife96's Avatar
Default ls vtec turbo problems
ran good until couple days ago its a ls vtec turbo stock injectors stock fuel pump p72 ecu stock...it runs good but when u press the gas kinda fast it bogs down then revs it didnt do it until couple days ago..already checked injectors and cleaned them changed tps and map sensor and done put like 3 different distributors in and it still does same thing new wires sparkplugs to...anyone got any idea wht it might be? was supposed to go get tuned this weekend but i got to get this fixed now
Old Apr 21, 2010 | 07:59 PM
MoreBoostPlease's Avatar
Default Re: ls vtec turbo problems
You need aftermarket injectors (get some DSM 450s they are like 100 bucks) also get a walbro 255 they are cheap too like 100-120, then get it tuned, see how it runs then, i bet its waaaaaaay better
Old Apr 22, 2010 | 01:44 PM
lowlife96's Avatar
i have 255 pump and dsm 450s but im not puttin then on untill i take it to get tuned...it did run fine and really good but now it just wants to cut out when u press the gas fast like it bogs for a sec then revs...it didnt do it before a couple days ago ago
Old Apr 22, 2010 | 02:08 PM
mouab18c1's Avatar
You need a tune. That is your problem. Not feeding enough fuel for your motor
Old Apr 22, 2010 | 02:56 PM
lowlife96's Avatar
but y did it run good and didnt do this before?
lowlife96's Avatar
it only running 6 pounds of boost
Old Apr 22, 2010 | 04:26 PM
Blue00Si's Avatar
like said above put pump and injectors in and be done with it. shouldnt have any problems.
Old Apr 22, 2010 | 05:15 PM
lowlife96's Avatar
thanks for input peoples!
Old Apr 22, 2010 | 06:28 PM
mouab18c1's Avatar
Wrong he still needs a tune even with new injectors and a new pump. A car will run fine while the engine is cold because it idles higher and is burning more fuel. Once it warms up and the ecu goes into closed loop then it will start to run like **** if it does not have a tune. The ecu will not read the new injectors unless it is corrected on the ecu itself by a tuner.
Old Apr 23, 2010 | 11:59 PM
lowlife96's Avatar
it was the missing link!!
smurf357
Sep 13, 2015 08:10 AM
Mrmopar
Dec 24, 2012 06:54 PM
95ls/v-t
Mar 4, 2011 01:19 PM
track_assassin
Dec 15, 2007 05:17 AM
