ls/vtec turbo need help please!!
Old 06-18-2007, 08:35 AM
jdmrenzo's Avatar
Default ls/vtec turbo need help please!!
im in the process of installing my b16 head into my fully built b18a1 block..i purchased the golden eagle vtec conversion kit that came with a 81mm headgasket but my block is bored to 81.5mm.
i need to know if the 81mm headgasket would be allright to use w/ the 81.5mm block. NEED ANSWER ASAP PLEASE
THANX
Old 06-18-2007, 08:46 AM
4g hatch's Avatar
it should be fine. i think the cylinder holes in the gasket are a bit larger than stock anyway. by the way who built your motor. is there any good tuners in winchester
Old 06-18-2007, 08:59 AM
jdmrenzo's Avatar
Default Re: (4g hatch)
thanx for the answer...i think it would be fine too but ..i just wanna doble check...
i do not live in winchester anymore but the block was sleeved in tyson corners at a machine shop..they also balanced and polished the crank, installed the pistons, rods, bearings...i did the rest...(water pump, oil pump, etc)
I built the head myself..thats pretty easy.. but im hoping to get at least 550 to the wheels with a gt40 turbo...its going on a crx so hope to make 10 sec pases...
ohh by the way there;s a place in winchester called AR FABRICATION..i heard they do pretty good work
Old 06-18-2007, 11:16 AM
4g hatch's Avatar
sounds like a great setup. it should run its *** off in a crx. are u outa state now. i got a ls bottom end with itr pistons. im gonna go the all motor route but man turbo's are fast
Old 06-19-2007, 11:23 AM
jdmrenzo's Avatar
sorry it took me so long to answer...hehe...no man im in leesburg now...thats in loudoun county like 1 hour from winchester
where are you at??
Old 06-19-2007, 03:41 PM
4g hatch's Avatar
im like 20 minutes from harrisonburg
JDMCIVIC919
05-04-2012 02:52 PM
nodamnnamesleft
09-10-2005 05:50 AM
crxhf19
04-15-2005 10:53 AM
ExplicitSpeed
06-10-2004 03:59 PM
B17aTrbo
10-03-2002 03:14 PM
Quick Reply: ls/vtec turbo need help please!!
