LS/VTEC? on timing belt and head gasket .
Old Aug 30, 2003 | 07:53 PM
biggdogg's Avatar
Default LS/VTEC? on timing belt and head gasket .
if i use a b18b block 2nd gen oil and water pump and a 2nd gen b16 head which timing belt should i get ,gsr?
Old Aug 30, 2003 | 09:38 PM
MadPJ7's Avatar
If you are using the GSR/ITR oil pump you'll use the GSR/ITR timing belt. If it's the LS oil pump, you can use your stock timing belt (though it's a great time to replace it.) Use a headgasket from the LS.
Let me know if you run into any other problems MadPJ7@netscape.net
Old Aug 31, 2003 | 12:03 AM
mmuller's Avatar
Mad Scientist
Default Re: (MadPJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadPJ7 &raquo;</TD></TR><TR><TD CLASS="quote">If you are using the GSR/ITR oil pump you'll use the GSR/ITR timing belt. If it's the LS oil pump, you can use your stock timing belt (though it's a great time to replace it.) Use a headgasket from the LS.
Let me know if you run into any other problems MadPJ7@netscape.net</TD></TR></TABLE>
No, if you use a vtec WATER pump=vtec t-belt , non/vtec pump=non vtec belt
da.nizzle
May 5, 2008 12:10 PM
prolifik22
Feb 10, 2008 06:35 PM
MelloYelloCRX
Oct 12, 2007 02:21 PM
SL0WEGG
May 5, 2005 02:51 PM
