LS/VTEC questions on oem cams..
Old Aug 10, 2005 | 08:02 PM
93FastLs's Avatar
Default LS/VTEC questions on oem cams..
im building a lsvtec...motor the head is b17..now my question is...should i keep the b17 cams or should i change them out for a set of 95 gsr cams that i have layen around ? what i really need to know is what kind of power gain will i get it i use thE 95 GSR CAMS
Old Aug 11, 2005 | 08:47 AM
miller.91.HB's Avatar
Default Re: LS/VTEC questions on oem cams.. (93FastLs)
I might be wrong but I'm pretty sure that B16/17 cams are identical. That being said, the gsr cams have a bit more lift on the intake side and more duration on both sides than B16/17 cams.
They aren't going to be a huge improvement but if you have them laying around I would suggest throwing them in.
Old Aug 11, 2005 | 10:48 AM
93FastLs's Avatar
with more lift and duration what will that give me ??
Old Aug 11, 2005 | 10:54 AM
gsrious's Avatar
Default Re: (93FastLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs &raquo;</TD></TR><TR><TD CLASS="quote">with more lift and duration what will that give me ?? </TD></TR></TABLE>
we don't really know until you try them on.
Old Aug 11, 2005 | 12:04 PM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
CTR's or ITR's....best bang for the buck...
Old Aug 11, 2005 | 03:25 PM
H.Veras's Avatar
Well, more lift and duration will give you more power. More duration is going to give you more power at higher rpm, and more lift is going to give you more power at certain lower rpm.
wearyfurball
16
Feb 19, 2008 08:54 AM
GWInquisitor14
Sep 7, 2005 06:25 AM
doublek
Jul 29, 2005 05:17 PM
blkgsr03
Aug 3, 2004 05:12 AM
SIReg9
Aug 13, 2003 03:18 PM
