Ls/Vtec question READ !!!!!!
Old Nov 22, 2001 | 06:25 AM
integra81's Avatar
New User
Default Ls/Vtec question READ !!!!!!
what is the difference between the integra ls and the gsr engine block? what makes the ls block so much better, as in ls/vtec? i was thinking of putting the internals of an ls into a gsr block with a gsr head, then no drilling will be needed. I know the ls block is bigger but if it was resleeved would it be the same? please get back to me!
Old Nov 22, 2001 | 07:25 AM
rainforest's Avatar
Default Re: Ls/Vtec question READ !!!!!! (integra81)
ls block has a 89mm stroke and gsr has a 87mm stroke.
Old Nov 22, 2001 | 04:16 PM
integra81's Avatar
New User
Default Re: Ls/Vtec question READ !!!!!! (rainforest)
so can u put an ls crankshaft in a gsr for more torque
Old Nov 22, 2001 | 06:57 PM
bruthaboost's Avatar
Yes.
Old Nov 22, 2001 | 07:14 PM
Finest's Avatar
Default Re: Ls/Vtec question READ !!!!!! (b18bpwr)
You'll be better off resleeving your GSR block with bigger bore cylinders, then dropping in overbore pistons.
Old Nov 23, 2001 | 09:07 AM
rtype11's Avatar
oil squirters for piston skirt / cooling, 3 middle main cap girdle brace - thats it same bore.
jdmdikk
Jul 10, 2008 06:00 AM
typeRSXS
Mar 24, 2004 03:54 PM
94si94cx
Jan 24, 2003 06:50 AM
2XS
Jul 18, 2002 09:30 PM
