Ls/Vtec No start ?
Old Oct 14, 2011 | 05:55 AM
  #26
fcm's Avatar
fcm
Old Fart
Default Re: Ls/Vtec No start ?
The 12V+ to the injectors is not a pulse, it is a constant, it is supplied by the PGM-FI Main Relay, [fuel injector relay] it has to stay at 12V+ as long as the ign. key is in the run or start position.
Yes, you can test it with a meter, test the lead that is the same color on all 4 injector plugs. 94
Old Oct 20, 2011 | 07:02 AM
  #27
em1pusha99's Avatar
Streetplayas you were right, The Hondata 4 bar was causing my no start. When I got up to Locash he went into the ECU and changed the settings for the map and after a few hours we settled at this.....
Old Oct 20, 2011 | 11:34 AM
  #28
Markyboy's Avatar
Did you check timing lsvtec timing is never right on and it will run with the gsr ecu just shitty ciz it needs a tune but my guess is timing is off or to advanced. Of you checked everything else reset the timing and run it and go straight to the tuners
Old Oct 20, 2011 | 05:09 PM
  #29
em1pusha99's Avatar
did you even read threw this thread? or are you saying those are shitty power numbers? it's been tuned and runs like a champ.
Old Oct 20, 2011 | 05:25 PM
  #30
Markyboy's Avatar
I didnt see that it was 2 pages my b
staz0loaf
Jul 29, 2013 07:40 PM
DuecedSol
22
Jul 26, 2012 05:15 AM
pandaek
Jan 30, 2008 04:04 PM
I got a honda
11
Nov 7, 2005 09:12 PM
GSRfoedoe
Jun 5, 2003 02:17 PM
