ls/vtec issue
Old May 2, 2005 | 02:36 PM
kevslive95's Avatar
Default ls/vtec issue
I just built an ls/vtec and swapped it into my 96 integra. Everything works perfect except 2 things. The first is when the car is idling just sitting there it warms up to a little more than a quarter of the way on the temp gauge on the dash, as soon as i start driving it drops almost to the "C" marks on the gauge, same thing happens when I get on the gas. Then i'll let it sit at idle right after and the gauge moves back up again. What is this from or is it normal. The second problem is when i rev the car out say from 3k in 3rd gear for example the check engine light will come on anywhere from 6 or 7 rpms then i just turn the key off then on again and the light is gone. I do have a ls trans on my swap so the gears are real long but i don't understand what causes this. someone help me out
Old May 2, 2005 | 05:41 PM
93aztecgreenGSR's Avatar
Default Re: ls/vtec issue (kevslive95)
need a new thermostat.
Old May 2, 2005 | 07:43 PM
Jmunk's Avatar
New thermostat to fix the cooling problem and check the code and get back to us for the answer to that.
Old May 3, 2005 | 02:49 PM
kevslive95's Avatar
Default Re: (Jmunk)
I tried a new thermostat already i even changed the thermostat housing because of my cooling fan not kicking on. I don't understand how the thermostat would let it warm up and then drop at the temp gauge as soon as i start driving. I have a gsr water pump on the block. Now for the other issue would having an ls distributor or ls trans cause this long revving error code problem.
Old May 3, 2005 | 03:19 PM
Default Re: (kevslive95)
i dont think there is a long rev code. i suggest you check the code again. if you changed the thermostat already then you should take a look at your coolant tempetue wire.
Old May 5, 2005 | 04:45 AM
kevslive95's Avatar
Default Re: (93aztecgreenGSR)
I threw a 21 and 23 code but heres the thing i'm popping vtec even after the check engine light is on. and for the knock sensor we have it drill and tapped into the block where the upper alternator bracket inner bolt is i just don't get it
Old May 5, 2005 | 03:43 PM
i suggest you look over ur wirings to see if it in the right pin.
Old May 6, 2005 | 12:04 PM
DA-nteg's Avatar
check grounds
Old May 7, 2005 | 05:38 PM
kevslive95's Avatar
there is know more 21 code. It is now just throwing 23 knock sensor. It only throws the check engine light in higher rpms at the 3rd, 4th, and 5th gears only. the knock sensor on this motor is drilled and tapped on the upper alternator bracket where the bolt near the #4 cylinder was, wire straight in to the ecu. Also why does this code pop intermittently in the upper gears, 3rd gear and up at high rpms. then turn the ignition off and then back and the light is off but 23 will be in the ecu
Old May 8, 2005 | 06:07 AM
B16'D DA9's Avatar
chip ur ecu and get rid of the knock sensor thats what im doing with mine...much easier i hear less prob's.
tothewall
Mar 9, 2010 06:06 PM
lsvtecpower
Aug 9, 2008 03:43 PM
MiKeAhOwSkI
Dec 24, 2004 11:54 AM
98cwitr
Dec 22, 2003 02:51 PM
ls_vtec_b18a1
Feb 24, 2003 04:44 PM
