ls/vtec into 92 vx hatch
Old Jun 3, 2003 | 11:40 PM
Combustion Contraption's Avatar
Default ls/vtec into 92 vx hatch
ok im gonna be dropping an ls/vtec into my 92 vx hatch soon and so far the only problems i have run into and cant figure out are how to convert the seven wire o2 sensor to a four wire and if i can use the starter from my vx tranny on my b16 tranny and last but not least if i can use the alternator from my vx d series motor? i know im a dumbass, but im trying! just in case anyone cares, the setup is b18a block, gs-r block girdle, spoon balanced ITR pistons, shot peened STOCK ls rods, ported and polished gs-r head,skunk2 valvetrain, ITR cams, dc sports 4-1 header. bleh, ok that does it.
Old Jun 4, 2003 | 03:45 AM
J2turbo21's Avatar
Default Re: ls/vtec into 92 vx hatch (LsVtec92Hatch)
I dont think the starter will work.The alternator might but your gonna have to rig something up because i did it ghetto on my first swap.Also the VX should have a 5 wire o2 not a seven wire.
Old Jun 4, 2003 | 01:13 PM
Default Re: ls/vtec into 92 vx hatch (J2turbo21)
ttt
Old Jun 4, 2003 | 02:29 PM
anyone else have any experience with this?
Old Jun 4, 2003 | 02:30 PM
dfoxengr's Avatar
Default Re: (LsVtec92Hatch)
ill straight trade you a 4wire o2, (what u need) for the 5wire one. LMK
Old Jun 4, 2003 | 04:25 PM
Kataku2K3's Avatar
Default Re: (hybridvteceg)
I originally made this diagram to show others how to convert from the single wire oxygen sensor to the standard 4 pin... It will work the same way for you, it's just a lot easier... Eliminate out what you do not need... Good Luck and let me know if you need anything else... Peace
Old Jun 4, 2003 | 05:06 PM
wow, that helps alot man. appreciate it. any news on the alternator or starter?
Old Jun 6, 2003 | 01:07 PM
anyone?
Old Jun 7, 2003 | 12:12 PM
riceboyEFsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">wow, that helps alot man. appreciate it. any news on the alternator or starter?</TD></TR></TABLE>
the starter and alt. will not work
boostedsohcvtec
Jun 17, 2011 10:38 AM
sonicivic
Feb 17, 2006 09:47 AM
VXJDMHATCH
Oct 14, 2005 07:18 AM
G3gsr
May 3, 2003 04:52 PM
hondaeg5
Jun 24, 2002 03:49 PM
