Ls/vtec idling problems...HELP!!!
Old Oct 24, 2008 | 02:06 PM
Boosted_CRX_507's Avatar
Default Ls/vtec idling problems...HELP!!!
ok so most of the time my car idles really good, it stays on and everything...sometimes when i put it in reverse it starts to sound rough, like if it were running on 3 cylinders, after that i put it back in first gear and it does the same thing, i drive and everytime i push the clutch in the rpm's drop really low and the car shuts off in like 2 seconds...it wont idle worth ****...this only happens when i put reverse in.
anyone have an idea wat this could be?
Old Oct 24, 2008 | 07:39 PM
Default Re: Ls/vtec idling problems...HELP!!! (Boosted_CRX_507)
anyone????
Old Oct 25, 2008 | 08:37 AM
si vtec ftw's Avatar
could be a shorted wire for your reverse lights
do they come on properly?
Old Oct 25, 2008 | 10:20 PM
Default Re: Ls/vtec idling problems...HELP!!! (si vtec ftw)
yea man they work good, unplugged them and it does the same thing
my idle is all [freak]ed up dude, [freak]ed up when its cold
so im preety sure my FITV is shot and my IACV is shot, gonna replace the iacv and clean the FITV
ill let you know if i still have this problem...i might have a shorter ground somewhere tho
sometimes its hard for my hid's to come and their dim, when i rev up they get brighter, all the grounds are tight tho...also, when i put my turn signal on my headlights start flickering.
Old Oct 25, 2008 | 10:22 PM
btw. the same rough idling problem happens sometime when the car has been running for a while and i shut it off for like 5 minutes...it wont idle after i ahve to sit there and rev the **** up, thats when my rpm's drop to 0 when i go shift gears.
Old Oct 26, 2008 | 06:05 AM
could be a ground
make sure the ground on your alternator is nice and tight
let me know what happens
Old Oct 31, 2008 | 09:49 AM
alright, replaced my grounds the other day and now the car idles like **** only when its cold...think my fitv is bad, took it out and tigtened up that white cap and didnt do nothing, if i hold the car at 2 grand it will eventuallly sound and idle good, think its running on 3 cylinders at first
the thing about the reverse lights was the grounds, i may have to check the alternator ground tho, when i turn my hid's on it starts doing it and making it sound like its running on 3 cylinders.
when the problem happens it misfires...sounds like its running on 3 cylinders...everytime i start the car it does it, wether its cold or hot...then it goes away after i hold the idle at 2k for at least 30 seconds.
bad dizzy cap???
hondaboi7
Apr 11, 2011 11:42 AM
InTheLBC20
Dec 11, 2009 07:13 AM
EKJOE
Jan 27, 2009 05:48 PM
crxsi8
Jan 13, 2006 03:52 PM
VTECth1s
Nov 17, 2005 12:27 PM
