ls/vtec head bolts
Old Mar 8, 2004 | 04:48 PM
kerby116's Avatar
Default ls/vtec head bolts
ok, heres the problem. i going ls/vtec and i want to use my ls head bolts. from looking around i found i cant use all of them because 2 are to long. does any one know where the 2 long ones are located? or the size i will need to use on a b16 head?
Old Mar 8, 2004 | 05:06 PM
torr's Avatar
Default Re: ls/vtec head bolts (kerby116)
i would get gsr arp headstuds. but the two short ones go in the middle, one on top and the other right under it.
Old Mar 8, 2004 | 05:08 PM
turbo96wr's Avatar
run head stud's and the 2 long one's are 1,2 in the torque sequence.
Old Mar 9, 2004 | 03:04 AM
B17AGSR's Avatar
get 94-01 gsr headstuds
Old Mar 9, 2004 | 06:41 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: ls/vtec head bolts (B17AGSR)
correct, when you do an ls/vtec swap, you'll need the gsr studs.
Old Mar 9, 2004 | 06:47 PM
jrcrx's Avatar
Default Re: ls/vtec head bolts (vtecb20coupe)
Grab the the pebble from my hand if you can grasshoopper to see if you are ready!
Old Mar 9, 2004 | 08:47 PM
Rod.'s Avatar
Default Re: ls/vtec head bolts (jrcrx)
gsr or itr head studs
almostjdmeg
Jan 3, 2009 07:41 AM
brian3676
Dec 14, 2005 05:45 PM
wdyno
May 31, 2004 02:57 PM
frostt3ch
Dec 31, 2003 08:18 PM
SoloSol
Jan 9, 2002 04:38 PM
