LS/vtec or B20/vtec?
Old May 2, 2004 | 01:16 PM
AdvanTech's Avatar
Default LS/vtec or B20/vtec?
I was thinking about doing a swap, and I know that the transformation would take awhile, so I thought why not get a non-vtec engine first, then save up for a vtec head, and then turbo it last? (if that ever happens lol) For sure this would not happen overnight, but I was just wondering what the advantages/disadvantages were of each setup. Any help would be appreciated!
Old May 3, 2004 | 12:47 PM
I3ackfire's Avatar
Default Re: LS/vtec or B20/vtec? (AdvanTech)
I am pretty sure this same thread was discused a week or two ago...
Old May 3, 2004 | 12:58 PM
AdvanTech's Avatar
Default Re: LS/vtec or B20/vtec? (I3ackfire)
ok, I'll look for it then. Thanks
Old May 3, 2004 | 01:28 PM
AdvanTech's Avatar
I did a search and I found the thread you were talking about. So the B20/vtec has more potential to make power as it has a bigger bore than an LS/vtec, but the LS/vtec is cheaper. Is that right, and is there anything that was missed? Thanks for the help!
Old May 3, 2004 | 02:09 PM
XDEep's Avatar
Default Re: (AdvanTech)
ya you might have missed the issue with the weaker b20 cylinder walls, especially if you plan on boosting more than 8-10psi.
Old May 3, 2004 | 02:13 PM
AdvanTech's Avatar
Default Re: (XDEep)
Really? That's good to know. lol But is there any way that I can reinforce them?
Old May 3, 2004 | 02:15 PM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdvanTech &raquo;</TD></TR><TR><TD CLASS="quote">Really? That's good to know. lol But is there any way that I can reinforce them?</TD></TR></TABLE>
you can try block posting/pinning or blockguard but its better to re-sleeve. if you're gonna re-sleeve you might as well re-sleeve an LS since the block is otherwise exactly the same and cheaper.
Old May 3, 2004 | 02:19 PM
AdvanTech's Avatar
Default Re: (XDEep)
So the slightly bigger bore of a B20 isn't much of an advantage over an LS engine?
Old May 3, 2004 | 06:26 PM
b20_ed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdvanTech &raquo;</TD></TR><TR><TD CLASS="quote">So the slightly bigger bore of a B20 isn't much of an advantage over an LS engine?</TD></TR></TABLE>
yupp. damned sleeves...
Old May 3, 2004 | 07:59 PM
Sliced Beard's Avatar
Default Re: (b20_EK)
the b20 has only three sleeves compared to a b18a/b
the number two and three sleeves are one piece and thus are thinner due to the fact that the cylinder bore centers are so close together. for boost this is an unreliable thing and can cause fatigue wear after time
i say go with the LS beacuse of lack of immediate problems until you get it sleeved
also you have wayy more options for pistons with the LS over the b20 because of bore. there are tons of options for pistons for an 81mm bore when there are only two options for the b20 (these options i speak of are of coarse stock honda pistons)
Old May 4, 2004 | 11:28 AM
AdvanTech's Avatar
Thanks for all your help I hope this helps me come to a conclusion..
prjdmek
Mar 10, 2010 09:24 AM
Civic94cx
Dec 14, 2007 08:29 AM
honda_mike
Nov 19, 2005 09:47 PM
95_hatch
May 5, 2004 04:49 PM
Sassafrass
Jan 5, 2003 10:11 PM
