ls turbo problem
Old Sep 14, 2010 | 08:57 AM
poodangity's Avatar
Default ls turbo problem
i just finish turboing my hmo ls. so i am still workin out some kinks and i thought i got them all figured out and done so i went and raced a mustang last night and lost cyl 2 and there is a lot of smoke coming from the exhaust pipe and the mini filter on my valve cover is drenched in oil. any one got any ideas what i should do. i am ordering a head gasket today for it.
Old Sep 14, 2010 | 09:06 AM
kyden's Avatar
Default Re: ls turbo problem
sounds like you blew the motor.
Old Sep 15, 2010 | 09:29 PM
poodangity's Avatar
but how would it have blown the motor. i had to replace a valve in the head a few weeks back and reused the head gasket and bolt cause i was tight on money at the time. i mean if anything went i would think it was the head gasket or maybe some rings. but the motor only has 30,000 on it so i would not see any sense in the rings going.
Old Sep 15, 2010 | 09:49 PM
mouab18c1's Avatar
Reusing a headgasket was mistake #1. Not giving the motor the proper tune that it needed was mistake #2. Results in a screwed motor.
Old Sep 16, 2010 | 01:30 AM
poodangity's Avatar
but what could be wrong would anyone have a good idea? i pulled my plugs and the cylinder i lost was caused by the spark plug covered in oil. when the car is running it is not burning oil but antifreeze. so really my only guess is that it is the gasket. and i am only running 7 pounds of boost and it is getting tuned saturday in denver. i have the gasket now and the studs will be here first thing in the morning. so tomorrow morning i am pulling the head off. is there anything i need to look for to tell me anything?
Old Sep 16, 2010 | 09:45 AM
mouab18c1's Avatar
Only way to find out is to pull the head off. And or do a compression/ leak down test.
Old Sep 16, 2010 | 02:05 PM
poodangity's Avatar
pullin the head off in about twenty minutes i will let everyone know what i find
Old Sep 16, 2010 | 02:39 PM
dntnedvtec's Avatar
THIS.
You should have just waited till you got it tuned with a new head gasket before you went "racing". And seeing you went Street Racing, I can no longer help you, and neither should any one else. Good luck.
Old Sep 16, 2010 | 03:19 PM
JCRXTURBO20916's Avatar
YOU BLEW YOUR CLY, SORRY NO TUNE, IT HAPPENS.
Old Sep 16, 2010 | 03:32 PM
Flashmn's Avatar
No the oil that covered the spark plug was caused by something blown, piston ringlands, rings, cylinder itself, etc, which is the direct result of racing with an untuned engine.
Old Sep 16, 2010 | 06:28 PM
97ek-t's Avatar
im guessing some melted pistons!
Old Sep 18, 2010 | 01:54 AM
poodangity's Avatar
so i pulled the head......it was a piston. you were all correct. i had nitrous on the motor for a couple days and there is a spot near the back of the piston that is rounded off....so depressed. putting new pistons in tomorrow though lets hope for the best. cyl wall looks fine just for the record
Old Sep 28, 2010 | 08:42 AM
let us know how it goes.
Old Mar 19, 2011 | 09:11 PM
poodangity's Avatar
just for the record, i built the motor from top to bottom, eagle rods, ross pistons 20 over, eagle block guard, crower stage 2 turbo cams, crower everything in the head, srp everything, precision 6262 turbo, presicion wate gate, rams horn manifold, precision 1000 cc injectors, and s300
Old Mar 19, 2011 | 09:38 PM
2k.civic.si's Avatar
LOL....that motor is done....stick a fork in it
crxvtec16
Nov 29, 2008 01:00 PM
1 2 NV
21
Jul 19, 2006 09:39 AM
Singlecam4dr
Jul 7, 2006 08:49 PM
VTgringo
Aug 7, 2004 09:04 PM
