Ls Rod question
Old Sep 25, 2011 | 07:28 PM
ej1_civic's Avatar
Default Ls Rod question
I have ls rod with arp rod bolts in my b18c1 block and was wondering how high can I rev it too? Was wondering if i''ll hold up 9k.
Old Sep 26, 2011 | 01:15 PM
DartGuy25's Avatar
Default Re: Ls Rod question
TRY IT!!
Old Sep 26, 2011 | 01:32 PM
Julio@Bisimoto's Avatar
It would not be recommended for long extended periods of time.
With the cost of proper aftermarket rods being so inexpensive it is cheap insurance in investing on a proper set of H-beam steel rods. This will also allow you to support much higher cylinder pressures and rpm.
Check out our site: Bisimoto H-Beam Steel Rods
Old Sep 26, 2011 | 01:51 PM
ej1_civic's Avatar
Just wanted to know if I cant go 9k ill just stay at 8k for now thanks
Old Sep 26, 2011 | 03:53 PM
cibao2ner's Avatar
yea they should hold 9k no prob since u have the arp bolts..
Old Sep 26, 2011 | 05:00 PM
Not a problem just sharing some options for you
Old Sep 26, 2011 | 06:49 PM
ej1_civic's Avatar
I thought too but never know maybe 8.5 i might try
Old Oct 9, 2011 | 07:08 PM
streetplayas's Avatar
just depends on what you've done to the crank 9k is fine on a modified crank we rev them up too 11k on our all motor set ups with no problems cause of the fabrications we done to the crank but depends if you even need to go that high what cams are u runnin cause oem cams tend to stop producing power after 7200 rpm so theyre really no need to rev past 8k
ej1_civic
Jan 28, 2012 10:09 PM
(eg)upyours
Feb 17, 2010 09:39 AM
Spence
16
Sep 2, 2005 03:38 PM
cygnusX1
Sep 20, 2004 03:48 AM
stretracr
Jul 10, 2001 06:21 AM
