LS crank in GSR
Old Oct 12, 2004 | 09:01 PM
Prof. Crumb's Avatar
Default LS crank in GSR
i have a gsr turbo and wanted to put in an ls crank and rods but not gonna sleeve. i searched and foudn problems in crank hitting the oil squiters. can they be removed and be alright to up to 10 11 pounds with stock gsr pistosn and ls rods?debating if i got money to possibly run like forged pistons and like forged ls rods on the ls crank. i want forged pistons and rods but gotta see if i got money to? whats ur thoughts on this set up
Old Oct 12, 2004 | 09:12 PM
Sack Master's Avatar
Default Re: LS crank in GSR (Prof. Crumb)
Use the stock LS pistons if you are gonna do that. Gs-r pistons will yield higher than a 10:1 compression.
Old Oct 13, 2004 | 12:11 AM
psychotic_z's Avatar
Default Re: LS crank in GSR (Sack Master)
Stroking is always good, but you may want to lower the redline with all that boost and stroke. That's some stress on the poor thing, you know... But if you want 10 or 11 pounds, you'll hear from everyone and their mom that forged is the safest way to go. Stock LS rods and LS pistons (don't run GSR pistons, Sack got it right) should be ok that high, but you'll probably want to dish for the extra boost.
It's all good, whatever you want. But you need to have the oil squirters removed or bent (I think you can bend those little ******) for the LS crank. And you should know, LS rods with an LS crank. GSR pistons fit LS rods, but LS pistons will get you lower compression. Whatever floats your boat, dude...
Old Oct 13, 2004 | 05:00 AM
rsbad454's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prof. Crumb &raquo;</TD></TR><TR><TD CLASS="quote">i have a gsr turbo and wanted to put in an ls crank and rods but not gonna sleeve. i searched and foudn problems in crank hitting the oil squiters. can they be removed and be alright to up to 10 11 pounds with stock gsr pistosn and ls rods?debating if i got money to possibly run like forged pistons and like forged ls rods on the ls crank. i want forged pistons and rods but gotta see if i got money to? whats ur thoughts on this set up </TD></TR></TABLE>
crank may hit the squirters, but you would have to lay crank into block and see how much they will hit. You can bend them to clear crank throws....its been done before.
Old Oct 13, 2004 | 06:32 AM
mmuller's Avatar
Mad Scientist
Default Re: LS crank in GSR (rsbad454)
using a ls crank with your p72 pistons will give you a compression increase of about .2 , so it would be around 10.2
if you use pr4's comp. will be around 9.7 ish
Old Oct 13, 2004 | 11:18 PM
Default Re: LS crank in GSR (mmuller)
so use ls rods, pistons and crank if sayign stock, and im sure ill probably go with forged rods and pistons so but thats not a def, and is this good to run with turbo also. any more comments will help
Old Oct 14, 2004 | 10:44 AM
Just insane
Jun 25, 2012 07:28 PM
turbodelsolb16a2
Feb 7, 2010 07:57 AM
theme
11
Mar 11, 2009 05:06 PM
1.8T_EG
Mar 27, 2003 06:36 PM
