LS crank in a B18C
Old Mar 13, 2003 | 09:38 PM
Art701's Avatar
Default LS crank in a B18C
What's the purpose of this setup? are there any benefits to this? i would think that a GSR crank would be more stable at high rpm's due to the counter weights. . .maybe this setup is cheaper?
Old Mar 14, 2003 | 05:12 AM
GM2000ITR's Avatar
New User
Default Re: LS crank in a B18C (Art701)
Longer stroke. Balancing it the same on either.
Old Mar 14, 2003 | 08:07 AM
sweet's Avatar
most use it to gain a few more cc's of displacement, which then adds some more TQ/HP. IMO it's not really worth the hassle unless maybe the motor is torn down already. depending what rods/pistons are used it's important to make sure there is ample clearance between the valves and pistons.
Old Mar 14, 2003 | 08:36 PM
Art701's Avatar
nice thanks for the info, but will the LS crank have reliability issues? or is it just as good? as the GSR one?
Old Mar 18, 2003 | 09:45 PM
J2turbo21's Avatar
Do a search,i just did some searching on this too.Just type ls crank or crank or crankshaft.
Old Mar 19, 2003 | 06:47 AM
sweet's Avatar
Default Re: LS crank in a B18C (J2turbo21)
yes this was talked about in some other threads as J2turbo21 said.
the LS crank is basically the same as the GSR crank, cept for the longer stroke.
87.2 compared to 89.0 on the LS.
Lil_savage
Feb 20, 2019 03:19 AM
1SLaMMeDC2
Jul 22, 2010 10:14 AM
88hondahatch
Jul 15, 2003 07:03 AM
