LS/B20 VTEC question
Old Apr 2, 2003 | 09:14 PM
  #26
MikeMAN's Avatar
Default Re: LS/B20 VTEC question (lazy bum shaughn)
they have to be deepend some so the valve doesn't run into the top of the piston, but some people say they are fine when u use stock cams..
mike
Old Apr 3, 2003 | 02:57 AM
  #27
dfoxengr's Avatar
Default Re: LS/B20 VTEC question (tinkerbell)
because i said u dont need it,
LOL!
sorry to have questioned your reasoning Derek!
t..
its ok i forgive you..i just didnt feel like explaining
Old Apr 3, 2003 | 08:13 AM
  #28
Jeff C's Avatar
Default Re: LS/B20 VTEC question (MikeMAN)
I have always thought that the valve reliefs will be ok with stock cams and as long as you dont retard/advance the timing more than 4.
I think that vtec valves are 33mm and novtec's are 31mm.
This has been my understanding.
Old Apr 3, 2003 | 08:31 AM
  #29
owen_the_soyboy's Avatar
So do you guys think it would be safe to just use stock B20 sleeves with some high compression pistons as long as it's tuned?
yes no problem. with high compression your enemy will be headgaskets.
and a Block Girdle protects the bottom of the enging aka the block, from twisting and deforming during high revs... even aabove 8000 rpm the B20 and LS blocks will age faster without a block girdle attached. If you are building a B20vtec to run up to and not over 8000 rpm you could choose to NOT run a block girdle, but you still may see premature failure from this depending on what your circumstances of revving are... a road racer at 6000 rpm-8000rpm all day long every weekend will see his motor die sooner than a daily driver that sees 90% of its time at 5000 rpm.
[Modified by owen_the_soyboy, 12:35 PM 4/3/2003]
Old Apr 3, 2003 | 12:57 PM
  #30
lazy bum shaughn's Avatar
Default Re: LS/B20 VTEC question (owen_the_soyboy)
Thanks a lot guys. My plan is to use a B16 motor and tranny, B20 block, JE 12:1 pistons, Crower rods, GSR headbolts, and maybe a Z10 block girdle. Give me advice on what girdles to use. Also want some Skunk2 Stage 3 cams.
Old Apr 3, 2003 | 01:02 PM
  #31
dfoxengr's Avatar
u mean B16 head
get ARP headbolts
and if u really want a girdle the Z10 is cool, so is the well i forget the other name...
Old Apr 3, 2003 | 01:55 PM
  #32
Default Re: LS/B20 VTEC question (hybridvteceg)
I heard you use GSR headbolts because B16 ones are too short.
Old Apr 3, 2003 | 03:40 PM
  #33
Blaze45's Avatar
Brrraaaap!
Hondasaver, well know EF1 cams rule>>> http://www.ef-1.com
nuff said
Blaze
Old Apr 3, 2003 | 06:10 PM
  #34
dfoxengr's Avatar
yeah but get aftermarket ARP ones
Riceeater702
Jan 25, 2010 10:29 AM
Robs94gsr
Jan 12, 2010 05:04 PM
saver
36
Sep 26, 2006 08:34 PM
compwc18
Mar 14, 2004 02:22 PM
Boostless97Lude
Nov 20, 2002 07:19 PM
