Lower radiator hose deflating/suctioned
Old Feb 22, 2005 | 05:13 PM
sporkcrx's Avatar
Default Lower radiator hose deflating/suctioned
I forget what this means, but my lower radiator hose keeps deflating or suctioning itself flat. Headgasket problem?
Old Feb 22, 2005 | 09:00 PM
PrettyLude's Avatar
never heard of this one, im interested too
Old Feb 23, 2005 | 05:59 AM
JimBlake's Avatar
Default Re: (PrettyLude)
Is this when it's cooling down or does it do it when it's running?
When cooling down...
Check the smallest disk-seal in the radiator cap. That disk should pull down very easily. What that's for is so the system can suck coolant back in from the reservoir at the slightest vacuum. Then look for blockage in the little hose going over to the reservoir.
If it does this when running, I'm not sure. Maybe a really plugged-up radiator?
Old Feb 23, 2005 | 07:12 AM
sporkcrx's Avatar
Default Re: (JimBlake)
It only happens when it's cooled down or cooling down, when the car is off. I'll take your advice
Old Feb 23, 2005 | 07:33 AM
JimBlake's Avatar
Default Re: (sporkcrx)
If there's crud in those springs & seals of the cap, it's not even worth cleaning. New cap is pretty cheap.
Old Feb 23, 2005 | 07:46 AM
PrettyLude's Avatar
7 bucks for a new cap
Old Mar 3, 2005 | 11:00 AM
sporkcrx's Avatar
Replaced the greddy cap with a $10 korean cap, and it fixed the problem! thanks guys!
thechineseone
Mar 16, 2009 09:33 AM
dmxsoulja3
Dec 16, 2004 03:07 PM
The-LS
Jul 14, 2004 01:16 PM
