Lower engine mount questions
Old Feb 1, 2026 | 11:26 AM
Deadpixle's Avatar
Default Lower engine mount questions
My lower front torque mounts on my 2001 GSR are completely torn. I am guessing the transmission mount must also be bad. I'm planning on getting new lower mounts next week. I want stiffer torque mounts. I was thinking Megan as they look OEM but use stiffer rubber. I might go with a billet mount with stiff poly bushings. My question is, if I use stiff front torque mounts, do I need to use a stiff rear transmission mount too? Will it cause an OEM rear mount or the upper mounts to fail by shifting the load to the softer bushings?
Paul 631
Jan 5, 2013 07:18 AM
spcrxracer
Aug 20, 2012 07:34 PM
known
Feb 20, 2006 07:20 AM
Laura
May 23, 2005 01:21 PM
Clabbe
Jul 15, 2004 06:43 PM
