GSR Master Cylinder double flare???
okay to do the GSR master cylinder into an EG swap.....does the line that has to be flared need a double flare or just a single????
yes i searched....this is not answered specifically.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaceCity_USA »</TD></TR><TR><TD CLASS="quote">All of the brake lines on my 94 GSR are double flared.
okay cool so i will assume i need to double flare my civic line to keep it from leaking when i change to the integra fitting....thanks
okay it worked!!! and by the way...i removed my powersteering rack and went with a manual rack (DX).....i had a bit of trouble finding the correct size "bolt" to fit into the GSR master cylinder.....but after looking a t my power steering lines....ill be damed the fitting that i needed was right there all along....so i used the fitting from where the power steering rack connected to the hardline. crazy.
underb00steg6
10
Mar 31, 2007 10:38 AM
Suprdave
Aug 1, 2001 07:45 PM
