Low compression
Old May 1, 2016 | 10:31 PM
B16a2Em1's Avatar
Default Low compression
I had my b16 rebuilt, and did the usually hone,resuraced head/block, new rings, bearings etc..the block was assembled by a reputable shop. The engine starts right up but it seems to lack power. I compression tested it and got around 150-160 psi on all the cylinder. I'm not burning any oil, but when i did a wet compression test it shot up to 210 psi. After 500 miles are my piston rings still not seated? I did the usual half throttle pulls and decels when i broke in the engine. Any thoughts/help?
Old May 2, 2016 | 07:48 AM
fcm's Avatar
fcm
Old Fart
Default Re: Low compression
It does not seam like the rings have set yet, or rings did not get gapped properly. 94
Old May 2, 2016 | 10:12 AM
v4lu3s's Avatar
RTFM
If they have not set more they most likely won't ever set. What was your first warm up and drive like? Did you baby it and drive like a little old lady or did you rip on it some?
Old May 2, 2016 | 12:32 PM
B16a2Em1's Avatar
I primed it a like you usually do for a new motor, then started it, let it idle for 20 mins or so, and changed the oil, took it for a drive and went wot on it to 7k and decel'd. But after that i did leave the car sitting for a year, because i was too busy with school work. The car was running really rich when i first started it since it had stage one cams and i was running a base map, but i've since gotten a dyno tune, and it runs good, a:f is perfect.
honda305
10
Feb 15, 2009 06:34 PM
Calvinator
Nov 14, 2004 09:28 PM
96b18c
May 4, 2003 08:08 PM
98civicEX
Apr 8, 2003 10:55 AM
Brian_92GSR
Aug 1, 2002 08:38 PM
