power loss when hot
Old Jan 31, 2002 | 09:50 AM
johnzm's Avatar
Default power loss when hot
ok the car can run all day and when i turn it off fr 20 min, and let heat saturate it, then go drive again, the first 30 sec its got NO power. and its also lacking about 30HP the rest of the time. i checked comporession and i got 200-225 all across and the plugs are light grey on the tips. i was thinking the cat might be the problem, but i checked temp before and after the cat and theres 100 degree difference. do u think the cat is clogged anyqways? what else do u think could cause this problem ? BTW its a b16
Old Jan 31, 2002 | 10:17 AM
rainforest's Avatar
Default Re: power loss when hot (johnzm)
the cat can be clogged the only way to fix it is gut that bitch. that is proolly the problem
Old Jan 31, 2002 | 10:24 AM
johnzm's Avatar
Default Re: power loss when hot (rainforest)
yeah thats what i think too, but i was thinking of taking ot off first and seeing how the motor drives.. no cat dirving around will be fun for about 30 secuteil i get pulled over by a cop heehe
Old Jan 31, 2002 | 10:59 AM
pelotudo's Avatar
Yeah, I ran straight header once... Be prepared to take about 40 Tylenol with you...you WILL get a headache after about 14.538 seconds of driving it.
JB
Old Jan 31, 2002 | 11:54 AM
rainforest's Avatar
Default Re: power loss when hot (PeloTudo)
mine was in 12.7
Old Jan 31, 2002 | 12:01 PM
johnzm's Avatar
check it out, i just took temps and i got 230 before the cat and 200 after the cat.. u think thats the prob??
Old Jan 31, 2002 | 12:26 PM
johnzm's Avatar
everyone who has driven a b16 qwith the cat off i need to know.. did it kill ur bottom end? and how was the top end?
Old Jan 31, 2002 | 12:30 PM
pelotudo's Avatar
Bottom End? What bottom end? I went from like 1k to 4k in about 10 minutes
Top End? 4k to 8200 in .2 seconds
JB
Old Jan 31, 2002 | 12:53 PM
johnzm's Avatar
h3e is it really that bad without an exhaust???
Old Jan 31, 2002 | 02:16 PM
johnzm's Avatar
well, i tok my cat heatsheilds off, and when i hit it it rattles bad.
Old Feb 1, 2002 | 04:12 PM
johnzm's Avatar
hey guys i took the cat off and there was no power gain. so what else do u think could be casuing the poweer loss>??
DB1_559
Apr 30, 2009 10:45 PM
riceball777
Dec 7, 2005 08:02 AM
hondaciv3
Aug 26, 2003 07:16 AM
GOLF_PUNKS
32
May 20, 2003 03:13 PM
randomwalk101
Nov 7, 2001 12:36 PM
