loose flywheel bolts?
Old Sep 11, 2010 | 11:05 AM
haukurn's Avatar
Default loose flywheel bolts?
i have b18C6 civic EG6...i just broke in my new exedy OEM clutch, finally i could use my car (accelerate more, higher revs), and i noticed powerloss in 7000-9000rpm.. and then the other day when i was driving hard suddenly it started to sound like something was ratteling around in the clutch. i pulled my gearbox today, and i noticed that all my flywheel bolts were loose.
any ideas why this could have happened ?
damaged bolts ?
thanks
Old Sep 11, 2010 | 02:59 PM
igorka_91's Avatar
Default Re: loose flywheel bolts?
I had this on my b18c1. had to take of tranny atleast 2 times a week to tighten them. Changed out the fluweel to a exedy and everything is good. The oem flyweel was warped were the mating surface was to the cran shaft. Make shure that surface is clean asweeel. Oh and next time putt them on some tread lock.
Old Sep 12, 2010 | 03:28 AM
haukurn's Avatar
ok ill put some thread lock on the bolts. thank you !
Old Sep 12, 2010 | 05:41 AM
Allurian's Avatar
Yes thread lock is REQUIRED with flywheel bolts. That is the only way to properly install them.
Old Sep 12, 2010 | 07:18 PM
igorka_91's Avatar
Butt make shure youre mating surfaces are nice and clean. ON my flywell i had an uneven mating surface witch caused the flyweel to sit incorectly causing it to woble and losen up every 2 days.
And make shure you torque them correctly and not strip any bolts. One of mines is striped. Clean out the treads with some brake parts cleaner and some compresed air.
Old Sep 13, 2010 | 12:09 AM
haukurn's Avatar
yes, how do i make shure that mating surfaces are nice and clean ? sand them down with sandpaper ?
Old Sep 13, 2010 | 09:03 PM
igorka_91's Avatar
Yeah that would work. Just make shure its a nice and even mating surface.
Old Sep 13, 2010 | 09:07 PM
97ek-t's Avatar
if you put any sorta penatrating lube "wd-40,pb blaster" that will usally make them come loose afterwards
Old Sep 14, 2010 | 09:28 AM
igorka_91's Avatar
I dried mines out with comresed air for a good few minutes and then let it air dry for a lil while. Havent come lose yet in over 15k miles of daily beaten, redlined and abused.
Old Sep 14, 2010 | 03:20 PM
blackeg's Avatar
What the **** is mines? Are we talking about those guys in Chile?...
I have never used threadlocker on my flywheel bolts and I have been making hundreds of horsepower for many years with no problems.
The only time I have ever had a bolt back out was on a low power single cam setup where my friend put the bolts in with an airgun because the torque wrench only went to 80 ftlbs and not the 86 or 87 as per spec.
they could back out from uneven surfaces, or more likely uneven torque. make sure the motor is not rotating at all while tightening the bolts and go diagonal on the tightening sequence similar to how you would do a tire.
Old Sep 14, 2010 | 08:19 PM
igorka_91's Avatar
[QUOTE=blackeg;43537073]What the **** is mines? Are we talking about those guys in Chile?...
Welcome to honda-tech dot efin com. May i ask you how many languages do you know of the top of youre head? I know 3 and can speak them really well so one lil grammar mistake wont make a diference. Now if you kow more then just 1 or 2 or maybe 3. Grab a cold beer.
I decided to run treadlock because one of the treads in the crank was striped. Yey more grammar mistake.
Now back to subject.
Old Sep 15, 2010 | 05:32 AM
haukurn's Avatar
i used brake cleaner on the bolts, and put them in with blue threadlock.
they should stay in place now !
Old Sep 15, 2010 | 06:44 AM
str8JDMteggy's Avatar
I never used thread locker, never had a problem
Old Sep 15, 2010 | 07:00 AM
BJ91T's Avatar
I never reuse bolts and never use thread locker. No problems yet
Old Sep 15, 2010 | 07:01 AM
90blackcrx's Avatar
Red thread locker, torque to spec, never ever had an issue
Old Sep 15, 2010 | 09:11 AM
igorka_91's Avatar
X2
But it will be a pain in the @$$ to take them out next time. I heard that heating them up with a blow torch, or something along those lines, losens them up. Butt wouldnt that cause the area youre heating up to bend from the heat..?
denracho
Sep 28, 2007 05:02 AM
HatchSpeeD
Jul 14, 2007 04:46 PM
flip1199
Nov 7, 2005 11:07 AM
integraautox
Apr 4, 2003 08:36 AM
