Look at my head gasket!!
Old Jan 4, 2012 | 06:08 AM
Cantcatchme's Avatar
Default Look at my head gasket!!
I had a engine problem but not due to my head gasket but when I took the head gasket off I notice this.
So what do u guys think caused this so I can try and get it corrected before I do my rebuild?
Old Jan 4, 2012 | 06:43 AM
brandynEG's Avatar
Default Re: Look at my head gasket!!
what brand gasket is that? you got arp studs? or reused old ones? boosted/ na?
Old Jan 4, 2012 | 07:39 AM
brandynEG's Avatar
also, did you look to see if that coating stuck to your head or block a little when you pulled it off? if it wasn't smokin or heating up could be nothin honestly.
Old Jan 4, 2012 | 06:41 PM
tuck1crx's Avatar
clean and use copper spray-a-gasket. coating just stuck from being on there forever
Old Jan 4, 2012 | 08:48 PM
xkjnboix's Avatar
wtf !! hell no !! dont reuse a head gasket at all !! like stated before it probably got stuck from being on there so long. no biggie. clean the block and head surfaces and spray copper on your NEW headgasket for a no worry seal.
Old Jan 5, 2012 | 08:21 AM
tuck1crx's Avatar
Where did i ever say to re-use the old head gasket?
i didnt feel the need to state that he needed to use a new one and insult the guys intelligence. if he is able to to do the job he started I'm sure he is well aware that he needs to use a new one.
Old Jan 5, 2012 | 09:02 AM
grumblemarc's Avatar
The Grumpiest
Don't assume. Plenty people re-using parts that they shouldn't be.
Old Jan 5, 2012 | 10:18 AM
It's a cosmetic 3 layer head gasket and don't worry, I'm not re-using it lol. It's from my boosted setup and I was using 1/2 arp head studs to. So you guys think its just from being on the motor? The motor is 3yrs old btw.
Old Jan 5, 2012 | 02:42 PM
tuck1crx's Avatar
yes. sorry for all the confusion
Old Jan 5, 2012 | 03:26 PM
non-VTEC's Avatar
ditch the cometic gasket and run a OEM one. make sure both surfaces are flat and clean and torque properly. don't waste your money on copper spray stuff it's not needed.
abiliojr
Jun 3, 2015 11:09 PM
Sienile
26
May 18, 2012 04:34 AM
da_33
Jan 11, 2007 11:12 AM
onlinehost
Nov 14, 2005 08:14 PM
Egone
Feb 8, 2005 01:32 PM
