Loctite problem – need advice
Old Jan 21, 2002 | 09:55 AM
StanBo's Avatar
Default Loctite problem – need advice
I seem to have been a little overzealous with some Loctite Red and have bound a pin in an on/off valve.
Is there a solvent out there that will remove the Loctite?
I really don’t want to can this valve.
Thanks
Old Jan 21, 2002 | 11:03 AM
tegtyper's Avatar
Default Re: Loctite problem – need advice (StanBo)
heres from the faq at the loctite website. http://www.loctite.com/selector/faqs.html#removal
As a note: Methylene chloride is nasty . It might even be hard to get as a result of its bad rep. as a carninogen. Toluene or Xylene might be an acceptable alternative.
Q: How can I remove a fastener that is "permanently" locked in?
A: The application of heat is needed to remove a fastener that can't be removed with a hand tool. Temperatures of 325F and above is needed to break down a standard anaerobic, 500F for high temperature Anaerobics. A heat gun or propane torch is commonly used to do this process, and careful disassembly should occur while parts are still hot. Once apart, and cooled, use methylene chloride (Chisel #79040) to remove cured excess material. Always wipe down the fasteners with clean up solvent to remove the wax film that Chisel leaves on the surface.
Old Jan 21, 2002 | 11:05 AM
WAFFLES's Avatar
Default Re: Loctite problem – need advice (tegtyper)
yep, heatguns or hairdryers
Old Jan 23, 2002 | 01:28 PM
OneSunkCivic's Avatar
I work with it at work and we soak it in methyl acohol give it a try it can't hurt
Old Jan 23, 2002 | 05:42 PM
Duck Sauce's Avatar
Default Re: Loctite problem – need advice (OneSunkCivic)
Go ask on Thefiringline.com It's a firearms forum. A lot of people use LocTite red to install sights. Ask some of the guys there how to remove it. I remember there is a solvent that will remove it without having any ill effects. Good luck.
JimRaynor90
Aug 13, 2014 07:23 PM
hashback*
Feb 12, 2007 07:27 PM
RACEPAK
11
Dec 11, 2005 03:03 PM
EK FLY
Jul 30, 2005 10:14 PM
lanceh
Mar 31, 2003 07:44 AM
