line lock
Old Mar 26, 2005 | 03:54 PM
SOHCmaster's Avatar
Default line lock
Got a Moroso line lock for the drag strip, but just wondering if anyone has pics of one installed on a honda and which lines did they tap. I have no instructions here
Old Mar 26, 2005 | 04:29 PM
ScottEK's Avatar
Default Re: line lock (PK SPEED)
I have some on order as well. I can't remember the exact thread but there is another person on here running them. From what I remember you need two line lock solenoids and you install them before the proportioning valve. You wont need to add any line, you cut your line, put the solenoid in place and then you have to use a tool to flare the cut brake line. If I'm wrong on any of this please comment because I'm going to be doing this install next month.
Old Mar 26, 2005 | 05:15 PM
SOHCmaster's Avatar
never heard of using 2 line locks before
Old Mar 26, 2005 | 06:12 PM
ScottEK's Avatar
Default Re: (PK SPEED)
You have to unless you are running custom brake line setup. On a stock brake system the lines are divided, instead of one line being for the front and one line being for the back you have two lines controlling diagnol wheels. So if you installed one line lock you would only be able to do something like lock up the front right and rear left tire.
Old Mar 26, 2005 | 06:58 PM
SOHCmaster's Avatar
I only want to lock up one wheel. Can I do it that way with one cilnoid
Old Mar 26, 2005 | 10:37 PM
ScottEK's Avatar
You're not going to get much done with one cilinoid(sic), why would you only want to lock up one wheel?
Old Mar 26, 2005 | 10:42 PM
T4eg's Avatar
u need 2 because the brakes are split diagonal for example LF and RR, RF and LR
Old Mar 26, 2005 | 10:50 PM
SOHCmaster's Avatar
Default Re: (ScottEK)
Dont I just need to tap into one line to one wheel ??? I mean I only need it to hold me still at the light..
Old Apr 3, 2005 | 06:45 PM
turbociv's Avatar
you could do that, and it would work, but what if you wanted to preload the axles. Your back tire will slide.
supaman
Aug 1, 2016 05:27 AM
Soda Popinski
Dec 31, 2005 12:28 PM
turbospool
Aug 10, 2003 11:38 AM
