lets play a game called name that sound.....
Old Sep 24, 2002 | 11:08 AM
buckfittyone's Avatar
Default lets play a game called name that sound.....
since last night every time i get my car rolling i hear a sound coming from the front that sounds like a rattling/grinding sound. it doesnt happen when the engine is on and idling or even if your revving the motor it only happens when the car is in motion. anyone know what this could be?
Old Sep 24, 2002 | 12:20 PM
Default Re: lets play a game called name that sound..... (buckfittyone)
a few helpful replies is all i ask
Old Sep 24, 2002 | 12:32 PM
Perfectionist's Avatar
Does it go away when you apply the brakes? How about when you drift left or right? Your description is too vague and there's too many possibilities. Did you recently do something like lowering it or get big wheels? More detail is needed since I can't hear the noise from where I am sitting.
Old Sep 24, 2002 | 12:39 PM
Default Re: lets play a game called name that sound..... (Perfectionist)
when i apply the brakes the sound fades ,and it goes away when im at a complete stop the car is still at stock height and still has stock wheels.nothing on the car has been changed before or after i heard the sound,it just started happening,the car has about 160k miles on it
Old Sep 24, 2002 | 01:01 PM
gotnothing's Avatar
Since we're guessing anyway....
Recently, I had a strange sound coming from my car only when it was in motion. It actually sounded like plastic rubbing on one of my tires. It turned out that one of the metal shims/sound dampers on the back of one of my brake pads had shifted. It was actually metal rubbing on metal, but it didn't sound like that, so it took awhile to figure it out. It was annoying as all hell! Anyway, my example just proves that without a better description, your sound could be anything!! (Hehe, check your brake pads...)
Old Sep 24, 2002 | 02:03 PM
One time a stone flipped up and got into the pad/caliper area and made a nasty scraping sound. If the brakes check out, (there is a wear indicator, by the way, that will make noise if the pads are too worn), I would check out the wheel bearing(s).
Old Sep 24, 2002 | 05:25 PM
tinkerbell's Avatar
could also be hte dust sheild rubbing...
but it could be a twig stuck somewhere...
hth,
t..
Old Sep 24, 2002 | 05:56 PM
Mr. Choi's Avatar
New User
wheel bearing
Old Sep 24, 2002 | 06:42 PM
Kamin's Avatar
Default Re: lets play a game called name that sound..... (Chois i-VTEC)
wheel bearing
why do people always jump to a wheel bearing?
it could be an axle
it could be your brakes
its too vauge.
Old Sep 24, 2002 | 07:48 PM
Mr. Choi's Avatar
New User
Default Re: lets play a game called name that sound..... (KAMiN)
bceause the sound is heard when moving. the sound also doesnt change when braking. also look how many miles he has. the axles usually makes a clicking noise when turning. and usually never when driving straight.
Old Sep 24, 2002 | 07:58 PM
Fly By Ya's Avatar
it could be the muffler bearings...or possibly your blinker fluid is low....
naw, I dunno know man, the only thing I know is my 97 EX is doing the same damn thing and Ive got new wheel bearings/brakes. The only thing I can come up with is rack&pinion or cv joint or xomethin????
Old Sep 25, 2002 | 10:46 AM
Default Re: lets play a game called name that sound..... (Fly By Ya)
thank you all for the replies i appreciate the help.but does anyone know how to access the wheel bearings is this something i can do on my own ? i already have the front brakes off but i cant get to the little screws fon the brake sheild thing
Old Sep 25, 2002 | 11:04 AM
Spade's Avatar
Check the wheel bearings by jacking up the car, put your hands on the wheel at 12 and 6 and attempt to wiggle the wheel. If it wiggles, that's your bearings or CV joints.
ALso, check your calipers for all their bolts. I had a worry for a while....turned out one of the Slider bolts in the caliper was missing and the caliper would acuatlly bounce against the inside of the wheel.
Old Sep 25, 2002 | 12:20 PM
Fr0m4311's Avatar
Default Re: lets play a game called name that sound..... (gotnothing)
Samething happened to me
Old Sep 25, 2002 | 07:49 PM
Default Re: lets play a game called name that sound..... (Mad_hatter)
everything with the brakes is ok,now im convinced its a wheel bearing but i just cant get the round part off that holds the 4 lug nut bolts in place whats this peice called and how do i remove it?
Logan Gallagher
Mar 19, 2019 03:10 PM
Sunnybelle_76
Honda Civic (2001 - 2005)
Jul 22, 2012 08:26 AM
charada1
Honda Civic (2006 - 2015)
Sep 18, 2011 09:05 PM
blackriceman
Dec 3, 2004 04:48 AM
