Leakdown tester
Old Jul 19, 2002 | 10:45 AM
Mover's Avatar
Default Leakdown tester
I know this isn't the right place to post this but does anyone know where I could get a quality leakdown tester for a good price ? (other than Snap-On)
[Modified by Mover, 3:27 PM 7/19/2002]
Old Jul 19, 2002 | 10:50 AM
IHaveTurbos's Avatar
Default Re: Leakdown tester (Mover)
Get a Snap-Off I mean Snap-On. They are around 250.
Old Jul 19, 2002 | 10:53 AM
2point6's Avatar
Default Re: Leakdown tester (Hyundai4G63T)
work great too!
Old Jul 19, 2002 | 11:26 AM
Mover's Avatar
Default Re: Leakdown tester (2point6)
work great too!
I should have said 'other than Snap-On'. I know they work great but they're on the pricy side. Any other sources ?
Old Jul 19, 2002 | 11:42 AM
earl's Avatar
Summit $65.99 Part #900010
Old Jul 19, 2002 | 12:13 PM
kinesistech's Avatar
Default Re: Leakdown tester (earl)
You can make you own for even less.
Old Jul 19, 2002 | 02:37 PM
Mover's Avatar
Default Re: Leakdown tester (kinesistech)
Do you know what parts are required ? Seems that I've seen most of
the parts displayed at Home Depot or Sears.
If I can't find the parts, I'll just buy it from Summit
[Modified by Mover, 6:38 PM 7/19/2002]
Old Jul 19, 2002 | 04:11 PM
earl's Avatar
http://www.xs11.com/tips/misc/misc3.shtml
build your own tester
Old Jul 31, 2003 | 06:51 PM
Muckman's Avatar
Moderator in Chief
http://store.summitracing.com/...=3763
I bought this Leakdown tester from Summit. Which end is the input and which is the output (into the spark plug sockets)? lol I think the red hose screws into the spark plug sockets but im not sure if its fitted to the leakdown tester on the right side in hte picture. I called summit and the way the guy from summit described it - the peice where the red hose is fitted to is the input and where youd plug in a compressor hose.
And what size is the threading on the red hose? Called summit and they dont know. 14mm and 18mm is the other end that goes into the spark plug sockets not the hose diamater.
Old Jul 31, 2003 | 07:44 PM
blah13's Avatar
Default Re: Leakdown tester (Muckman)
Is it just me or does that look like a compression tester and not a leakdown tester? I've never seen the 2 gauge deal but it sure is damn similar if it is actually a leakdown tester. And how would it determine where its leaking from?
Old Aug 1, 2003 | 04:49 AM
EE_Chris's Avatar
Default Re: Leakdown tester (blah13)
The two gauge version shows you input pressure, as well as pressure lost.
How do you determine where its leaking from?
Intake = intake valve
Exhaust = exhaust valves
Oil cap = rings
Old Aug 1, 2003 | 06:09 AM
Muckman's Avatar
Moderator in Chief
Default Re: Leakdown tester (EE_Chris)
yo i had questions!
Old Aug 14, 2003 | 07:58 AM
Mover's Avatar
The way its pictured in your thread above is correct. The red hose goes to the sparkplug hole. The 2 pieces look like adapters for different spark plugs holes.
The compressed air fits in near the regulator.
Modified by Mover at 2:26 PM 8/14/2003
Old Aug 18, 2003 | 06:28 AM
obsidianG35's Avatar
If i get a good compression test reading.. is there any reason to do a leak down test?
Old Aug 18, 2003 | 10:09 AM
Muckman's Avatar
Moderator in Chief
Default Re: (r4integra)
No. Leakdown testing indicates what % of leakage you have in each cyclindar and it can also be used to help determine where the leakage is occuring.
Old Aug 18, 2003 | 01:00 PM
kwil666's Avatar
Default Re: (Muckman)
i tried to build my own it didnt really work at all. i ended up just using a friends later down the road. for the money i spent i could have bought one off ebay.
keith
whoa its len 2
Northern California
Oct 29, 2008 04:16 PM
blk97lude
May 3, 2003 04:24 PM
Usfrob22
Dec 30, 2002 03:53 PM
Shmeck
Oct 22, 2002 05:30 PM
