leakdown test feedback
Old Oct 18, 2003 | 10:23 AM
jeremy.'s Avatar
Default leakdown test feedback
did a leakdown test...setup is a b16 head on gsr block with itr pistons and bolt-ons. cylinder 1 and 2 were fine with 7% leak...but number 4 was 17% and number 3 was 25%. it might be the headgasket...how bad is this hurting me?
Old Oct 18, 2003 | 11:53 AM
Fkned's Avatar
Default Re: leakdown test feedback (ek_jeremy)
where was the leakage?Those #'s are pretty bad for 3&4If the headgasket is blown get it fixed obviously,and if not I guess you could run the motor for a while till it dies you'll just have to add oil all the time if it's the rings that are bad.
Old Oct 19, 2003 | 07:40 AM
jeremy.'s Avatar
Default Re: leakdown test feedback (fkned)
leak is coming back out the other cylinders
Old Oct 19, 2003 | 10:25 AM
Fkned's Avatar
if the air pressure is jumping cyls then the headgasket is bad.But not really sure what you mean.how do you know it's comming out of the other cyl?Is int mani and header off?
Old Oct 19, 2003 | 11:02 AM
jeremy.'s Avatar
no everything was left on...when he tested number 3 i put my ear on number 4 and i could hear and feel the air in the cylinder leaking out...vice versa with the number. thx for the feedback fkned
Old Oct 19, 2003 | 11:15 AM
Modifiedinteg's Avatar
if it a head gasket take the radadior cap off and if you see bubles then it is the head gasket and if its the rings pull the dip sitck and you can feel and hear air and if its the valves check if its coming from the exhuast or intake
Old Oct 19, 2003 | 02:46 PM
jeremy.'s Avatar
Default Re: leakdown test feedback (Modifiedinteg)
how bad is this performance wise?
Old Oct 19, 2003 | 02:54 PM
Project SSAP1's Avatar
i think that pretty bad...i got 2.5% on cyl's 1,2, & 4..cyl 3 was at 5%..this is on a gsr motor with 96k miles
Old Oct 19, 2003 | 04:54 PM
Mohudsolo's Avatar
Default Re: leakdown test feedback (Project H22DC4)
If the leak is the head gasket, it will get worse. Left long enough, it could get coolant into the oil which makes for a poor lubricant. If compression is leaking between cylinders, it can damage the head or block sealing surfaces. I'm assuming you could hear/feel the air from the adjacent cylinder leaking out the sparkplug hole which could be a good indication, unless air was leaking from the valves into the intake or exhaust and back into that cylinder if the valves were open.
Old Oct 19, 2003 | 08:33 PM
the DR.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">no everything was left on...when he tested number 3 i put my ear on number 4 and i could hear and feel the air in the cylinder leaking out...vice versa with the number. thx for the feedback fkned</TD></TR></TABLE>
your headgasket is busted between those 2 cylinders, change the gasket and make sure the block isnt warped
Old Oct 20, 2003 | 05:34 AM
jeremy.'s Avatar
Default Re: leakdown test feedback (SlicedBread)
but how long does it take to replace a headgasket? because the shop i go to charges 65 bucks an hour
Old Oct 20, 2003 | 07:05 AM
dirty_d_cx's Avatar
dude if you heve even the slightest mechanichal ability you can do it yourself
just go to an auto parts store and find a repair manual that fits your block and change your head gasket by following the step by step instructions just make shure you have all of the tools that are required
by doing this you will save yourself lots and lots of money and you will gain more
confidence towards your mechanichal ability
if there is no warpage the head gasket change it shouldn't take any more than four hours
Old Oct 20, 2003 | 02:47 PM
AzG35's Avatar
Default Re: leakdown test feedback (dirty_d_cx)
It may not bubble through the coolant if the gasket is blown between the 2 cylinders. There is no coolant between 1 cylinder to the next, only cylinder walls. If the leaking is adjacent, then the gasket is most likely blown. If its leaking from other cylinders, it may be from valves. Was there any air leaking from the intake?
Old Oct 20, 2003 | 07:22 PM
pro1342's Avatar
6% or more is the standard for a problem according to Honda.....
Old Oct 21, 2003 | 01:40 PM
jeremy.'s Avatar
Default Re: leakdown test feedback (AzSi22)
if it is the valves, what do i do about it? valve job?
Old Oct 21, 2003 | 01:54 PM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">if it is the valves, what do i do about it? valve job?</TD></TR></TABLE>
If it is the vavles, yes, most likely a valve job will fix it unless they are bent.
Old Oct 21, 2003 | 02:04 PM
jeremy.'s Avatar
isn't that a cheap job? what about the stems?
Old Oct 21, 2003 | 02:27 PM
Fkned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">isn't that a cheap job? what about the stems?</TD></TR></TABLE>Do you mean the guides?Okay now back to my previous ?where is the leak comming from int or exh mani or through the spark plug of the other cyl?
Old Oct 21, 2003 | 03:12 PM
jeremy.'s Avatar
through the other cylinders
Old Oct 21, 2003 | 06:31 PM
Fkned's Avatar
I understand that,but you need to tell me where the air is leaking from.If the air is comming out of the other cyls spark plug hole the gasket is bad,if it's leaking out of the int valves it could could back up into the other ports thru the manifold if the throttle blade is closed,so open the throttle and check it.
88 EF Hatch
Jul 11, 2009 09:50 PM
gsr dood
Feb 26, 2006 12:50 PM
jeremy.
Feb 2, 2004 09:28 AM
Stewie
Jan 27, 2003 12:44 PM
spoolin342
Jan 18, 2002 08:28 PM
