LCA bushings
Old Oct 1, 2006 | 06:34 PM
NathanielH's Avatar
Default LCA bushings
So i was jacking up my car today, to try and figure out a problem i have been haivng with my shift linkage (wich i posted for help with her, but to no avail ), when i noticed my rf lower control arm has a bushing (the one closest to the front bumper), that is insanley worn. i wiggled my tire side to side to check for a bad tie rod end, and noticed it was moving at least 1/4-1/2 inch. thats when i noticed it. anyways, my question is how do i get the bushing out? do i need a press? or will i have to take the control arm off and bring it into someone? anyhelp, or links would be apreciated. thankyou
Old Oct 1, 2006 | 08:20 PM
NathanielH's Avatar
Default Re: LCA bushings (NathanielH)
Old Oct 2, 2006 | 03:30 PM
NathanielH's Avatar
up she goes
Old Oct 4, 2006 | 05:18 AM
NathanielH's Avatar
Old Oct 4, 2006 | 09:17 AM
rmcdaniels's Avatar
I had to use a press to put new bushings in there, although I took the old bushing shell out by drilling out the rubber part and cutting the old shell out with a Dremel.
Old Oct 4, 2006 | 03:37 PM
NathanielH's Avatar
Default Re: LCA bushings (rmcdaniels)
cool, thanks for the info man. did you rent the press from an autozone or a store like that, or did you own it?
Old Oct 4, 2006 | 05:05 PM
rmcdaniels's Avatar
I went to a local shop and they let me use their 20-ton press and a selection of sockets to press the bushing sleeves. Harbor Freight sells one for $149, some day I'll buy one for myself.
StyleTEG
Nov 20, 2009 03:42 PM
AccordEX1991
Honda Civic (2001 - 2005)
19
Apr 14, 2008 11:35 AM
wlee112
28
Jun 25, 2007 08:08 PM
s1ngle
Suspension & Brakes
Oct 1, 2005 10:54 PM
SuperCivic
Sep 9, 2002 05:41 AM
