KYB struts or NOT?
Old Mar 10, 2004 | 11:20 AM
Must be VTEC's Avatar
Default KYB struts or NOT?
Sup guys? Have a 96 LS need struts. Have it lowerd but jus wonderin if KYB struts r ne good for a Integ? If u know, how do they ride? Stiff, bouncy, or what? Thanx for da help.
Old Mar 10, 2004 | 11:45 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: KYB struts or NOT? (Must be VTEC)
kyb is good but if you want better, save a little more for the koni's. ride quality also depends on your spring/coilover setup as well.
Old Mar 10, 2004 | 01:25 PM
timmy8151's Avatar
Default Re: KYB struts or NOT? (vtecb20coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecb20coupe &raquo;</TD></TR><TR><TD CLASS="quote">kyb is good but if you want better, save a little more for the koni's. ride quality also depends on your spring/coilover setup as well.</TD></TR></TABLE>
Yup, it really depends on what sort of springs you have on your car. I wouldn't recommend KYB AGX's on a car that is lowered more than 1.5". Also, the GR2's are really a stock replacement and shouldn't really be used for large drops.
lPat
Oct 6, 2007 08:34 AM
Flava
Suspension & Brakes
19
May 18, 2006 11:02 AM
asianalbutt
Dec 30, 2005 10:58 PM
mikeunreal
Suspension & Brakes
Nov 1, 2005 04:30 AM
anhhi
May 11, 2003 07:01 PM
