just changed diff in tranny now head gasket is bad??
Old Mar 8, 2004 | 12:28 AM
Ek00fbp's Avatar
Default just changed diff in tranny now head gasket is bad??
I just changed the diff in my tranny and now when I pulled the spark plugs the number three cylinder had coolant in it. Is it possibel that one of the bell housing bolts is not in correctly causing coolant to get into the cylinder? Also, I can't seem to get the bell housing bolt that is behind the starter all the way in, it sticks out about 3 inches and gets really hard to tighten. Am I putting it in the correct hole because it hand tightens most of the way. What could be the problems???
Old Mar 8, 2004 | 01:34 AM
ninesecteg's Avatar
Default Re: just changed diff in tranny now head gasket is bad?? (Ek00fbp)
i would say you have a blown head gasket. all the pressure in the coolant system is pushing water into your #3 cylinder after you shut it down. might want to get the deck and head resurfaced also. that bolt has nothing to do with it.
Old Mar 8, 2004 | 05:53 AM
Dan GSR's Avatar
Default Re: just changed diff in tranny now head gasket is bad?? (ninesecteg)
one has nothing to do with the other
Old Mar 8, 2004 | 10:40 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">Is it possibel that one of the bell housing bolts is not in correctly causing coolant to get into the cylinder?</TD></TR></TABLE>
I usually have a smart *** remark for these types of statements. But I don't even know how to comment on this one!
Old Mar 8, 2004 | 10:54 PM
Lucky3kgtvr4's Avatar
eden i told you they had nothing to do with each other. Ill pull your head tommorrow. The tranny bolts do not even come close to any water jackets.
Old Mar 9, 2004 | 07:18 AM
DxTrix's Avatar
Default Re: just changed diff in tranny now head gasket is bad?? (Lucky3kgtvr4)
Bump for THE GUMBANATOR VR4 . Edin with all the beating you have done to the car I think its time to replace the head gasket.
Old Mar 10, 2004 | 12:08 AM
Ek00fbp's Avatar
Default Re: just changed diff in tranny now head gasket is bad?? (DxTrix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DxTrix &raquo;</TD></TR><TR><TD CLASS="quote">Bump for THE GUMBANATOR VR4 . Edin with all the beating you have done to the car I think its time to replace the head gasket.</TD></TR></TABLE>
I got the head off and the gasket looks ok. I dont know hope its not something worse. Your the man PoooYa
Old Mar 10, 2004 | 12:09 AM
Ek00fbp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecteg &raquo;</TD></TR><TR><TD CLASS="quote">i would say you have a blown head gasket. all the pressure in the coolant system is pushing water into your #3 cylinder after you shut it down. might want to get the deck and head resurfaced also. that bolt has nothing to do with it.</TD></TR></TABLE>
Should I get the head resurfaced even though the car didn't over heat? Also, how do i resurface the deck?
Old Mar 10, 2004 | 12:14 AM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">I got the head off and the gasket looks ok. I dont know hope its not something worse. Your the man PoooYa</TD></TR></TABLE>
It may look like a perfectly fine gasket but there is more than likely a hair line fracture that you can't see and its allowing coolant into your cyl. Coolant doesn't just go into your cyl for no reason. New head gasket and you are all set!
Old Mar 10, 2004 | 12:25 AM
Ek00fbp's Avatar
Default Re: just changed diff in tranny now head gasket is bad?? (AMS MIKE)
I hope your right mike I really do, if your not im holding you and your shop personally responsible in giving me the AMS bullet proof sleeves
Old Mar 10, 2004 | 12:38 AM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek00fbp &raquo;</TD></TR><TR><TD CLASS="quote">I hope your right mike I really do, if your not im holding you and your shop personally responsible in giving me the AMS bullet proof sleeves </TD></TR></TABLE>
I am AMS MIKE. I am always right! And if I am wrong, Poya will be right!
P.S. Don't make me install my new block in my car.
Old Mar 10, 2004 | 07:33 AM
DxTrix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">
P.S. Don't make me install my new block in my car.</TD></TR></TABLE>
I like that (And if I am wrong, Poya will be right)
Old Mar 10, 2004 | 11:49 AM
ninesecteg's Avatar
just get the head checked for straightness. you don't want to put this all together and have it do this again. head gaskets just don't blow, unless your running a **** ton of boost, the machining is off, or very poor installation. nick
Old Mar 10, 2004 | 01:43 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninesecteg &raquo;</TD></TR><TR><TD CLASS="quote">unless your running a **** ton of boost</TD></TR></TABLE>
Dj^BaNNeD
May 19, 2007 02:02 PM
LaOstha
Sep 16, 2006 04:41 PM
Vtecme92
Jun 30, 2006 02:45 AM
johng
11
Mar 2, 2006 09:25 PM
civicmatt
Nov 27, 2003 06:13 PM
