kyb agx install question
Old Jul 8, 2004 | 11:57 AM
mmmVTEC's Avatar
Default kyb agx install question
how do you tighten the top nut when instead a hex hole the adjustment **** is there? to clarify, i mean that when i try to tighten the top nut, the whole shaft spins with it. on the OEM setup, i just used an allen wrench and a 14mm open end wrench, and now there's no spot for the allen wrench.
Old Jul 8, 2004 | 12:12 PM
deSigi's Avatar
If you notice at the top, in the threaded part of the shaft, there are two flat sections with no thread. Grap a pair of pliers, clamp it on there to prevent the shaft from twisting and tighten the top nut.
beoy9
Oct 17, 2009 10:54 PM
datssoled
Suspension & Brakes
Sep 5, 2007 10:49 AM
Jordans95si
Feb 12, 2006 01:28 PM
danelot
Apr 2, 2005 01:34 PM
AndyD
May 9, 2004 02:16 PM
