Koyo Drain plug broke... replacement?
Old Oct 18, 2008 | 06:37 PM
RyanStevenPhillips's Avatar
Default Koyo Drain plug broke... replacement?
It was from a 92-96 prelude radiator (R1979) and the plastic bolt is broken. I need a replacement..
Old Oct 19, 2008 | 02:06 PM
sackdz's Avatar
Default Re: Koyo Drain plug broke... replacement? (RyanStevenPhillips)
Is this a question, or a memorandum?
Old Oct 20, 2008 | 06:17 AM
Default Re: Koyo Drain plug broke... replacement? (sackdz)
Haha. Sorry. Where can I get one? I don't want to put gasket maker around it. If I know about pitch and all that I could just put any bolt in there, I just don't know it. Does anybody know the specs?
Old Oct 20, 2008 | 08:34 AM
sackdz's Avatar
http://www.hondaautomotivepart...81%29
$3.90
Old Oct 20, 2008 | 08:47 AM
The OEM plug doesn't fit. I already tried that. Thanks though. Does Koyo make OEM radiator? I didn't know. It's the aftermarket, big, shiny thing. It's pointless but I have it anyways.
Old Oct 20, 2008 | 08:49 AM
alphalanos's Avatar
try calling koyo
Old Oct 20, 2008 | 10:22 AM
sackdz's Avatar
Oh sorry I forgot you said Koyo. Nope Denso makes the OEM radiator, at least that one.
Did you destroy the bolt so much you can't tell the size/pitch?
Old Oct 20, 2008 | 01:19 PM
I don't know where to get a hold of Koyo from. I'm not sure whether certain sites are dealers or what. I imagine I can get a hold of them that way. I don't know how to measure pitch/size. I was just hoping someone could give me the numbers and I could search for that size bolt.
Old Oct 20, 2008 | 02:12 PM
sackdz's Avatar
You could take the remaining portion of the bolt to a hardware store and match it? You will probably need a seal or O-ring of some sort.
Old Oct 20, 2008 | 05:45 PM
alphalanos's Avatar
http://www.koyorad.com/contactus.html
Old Oct 22, 2008 | 05:57 PM
Default Re: Koyo Drain plug broke... replacement? (alphalanos)
They said I should just go through a distributor... so I'm going to try any of them and give you guys an update so someone else might know what to do in this situation.
Old Oct 22, 2008 | 06:22 PM
sackdz's Avatar
Did it break when you were trying to get it loose?
Old Oct 27, 2008 | 05:22 AM
I'm not sure when it broke. I had it in the garage and it must have fallen over or something. I sent a couple of emails... no response yet.
ezza
Feb 2, 2010 05:31 AM
bjscivic
Jan 9, 2010 08:42 AM
Tarlacon
Nov 6, 2008 11:35 PM
Powered By Garrett
Jul 17, 2008 06:05 PM
Paprika
10
Jan 1, 2007 02:19 AM
