knock sensor location on b18a
Old Jul 9, 2003 | 12:33 PM
untitled's Avatar
Default knock sensor location on b18a
i am doing an ls/vtec and will be using a pr3 ecu which requires the use of a knock sensor. problem: where should i put the knock sensor in the b18a? and i dont want to tap any thing out if i dont have to. thanx.
Old Jul 9, 2003 | 03:11 PM
poison's Avatar
Default Re: knock sensor location on b18a (88crx91integra)
KS is non existant on the B18A and when using an ECU that requires KS, you will need to tap into the block...
It's fairly simple.
I know there is a walk-through on c-speedracing.com and has been posted, but I can't find it right now.
HTH.
Old Jul 9, 2003 | 03:56 PM
untitled's Avatar
Default Re: knock sensor location on b18a (poison)
yea they put it in one of the alternator holes. any others. theres a guy that pmed me about a chip that eliminated knock, 2nd o2, and speed governor. good idea or no? i know a guy in town that will tune my car according to knock. solely on knock.
Old Jul 9, 2003 | 04:33 PM
poison's Avatar
Yes you can eliminate knock sensor as well, and those other things.
I would recommend doing it if you do not want to add knock sensor and such.
gabrielsousa
Nov 4, 2015 04:12 PM
cacahead1
Jun 8, 2005 04:41 PM
untitled
Aug 8, 2003 08:03 PM
