klinking noise
Old Mar 25, 2005 | 05:06 PM
kevslive95's Avatar
Default klinking noise
i built an ls/vtec with type r pistons when the motor was first warmed up we didn't notice that one of the injector wires were snipped. we fixed that. but after we checked some things out to make sure things looked good we took it for a ride and noticed for example if i was driving 40 mph and floored the gas you can hear a rattl;ing klinking noise from the engine. when i rev it up and then let rpms come down then rev it quick again you hear a knock noise. I am gonna look around the inside of the motor what should i look for.
Old Mar 25, 2005 | 07:43 PM
PrettyLude's Avatar
maybe the shields on the cat converter are loose?
Old Mar 26, 2005 | 01:00 AM
asefi944's Avatar
Default Re: klinking noise (kevslive95)
detonation.........pinging
Old Mar 26, 2005 | 10:54 AM
kevslive95's Avatar
Default Re: klinking noise (asefi944)
its not the cat or knocking. i found out what it was. it was the valve lashing the # 1 cylinder was to tight. it seems to be good now
97teg415
Jul 25, 2016 05:46 AM
DaveHoFoSho
Mar 7, 2009 07:05 PM
00-501itrspec
Oct 6, 2005 09:06 AM
vietnogi
Mar 24, 2005 04:51 PM
M.A.R.C.
May 22, 2002 06:30 AM
