engine noise
Old Mar 23, 2005 | 02:27 PM
vietnogi's Avatar
Default engine noise
i get a noise when i hit certain rpm, it sounds like a rattling noise. The noise is more severe if i dont warm the car up before driving. And its also more severe if i drive on a cold day, compared to a warm day. i thought it was a looose heat shield, but i made sure all of them are secure, any advice left?? please its a gay *** noise, i cant even hear my vtec cause of it, thnx lots for inputs.
Old Mar 23, 2005 | 02:38 PM
tilt's Avatar
Default Re: engine noise (vietnogi)
Sounds like your A-pipe is rattling. It's a common problem with gsrs.
Old Mar 23, 2005 | 04:59 PM
GSRerrr's Avatar
which rpms does it rattle at? rly high or rly low???
Old Mar 23, 2005 | 06:13 PM
ZEMX3's Avatar
Mine does it around 3 grand or so. Sounds like a loud rattle.
Old Mar 23, 2005 | 07:11 PM
Jimmy's Avatar
Global Moderator
The honey comb inside your catalytic converter could be breaking about... get underneath your car and tap on the CAT with a rubber mallet and see if you hear the sound... if so time for a new cat.
Old Mar 24, 2005 | 09:32 AM
xcguyxc's Avatar
Default Re: (Jimmy)
Jimmy's right that was what was wrong with mine pluse the cat was to small so i got a whistleing sound when the vtec kicked in
Old Mar 24, 2005 | 11:12 AM
vietnogi's Avatar
Default Re: engine noise (GSRerrr)
every other 1k rpm, mainly around 3k
Old Mar 24, 2005 | 11:18 AM
silva95teg's Avatar
i have a gay *** noise same thing but mine is an rs it is some shitty ratteling noise just like you described
Old Mar 24, 2005 | 01:07 PM
94twinv-tec's Avatar
I would like to know too. My gsr only rattles when I start the car. It will only rattle when it's cold and then stops when the engine gets warmer. I asked around and they said it might be one of my Valve springs being loose. I don't really know. Mine is from the engine it self, like the center of the engine.
Old Mar 24, 2005 | 03:26 PM
vietnogi's Avatar
how do u fix a loose valve spring? should i even do it myself?
Old Mar 24, 2005 | 04:51 PM
GSRerrr's Avatar
good question i wana know too.. do u need to take to a shop to fix valve springs? up
GsDAteg
Mar 18, 2006 12:40 PM
00-501itrspec
Oct 6, 2005 09:06 AM
ghettogk
Nov 15, 2004 06:38 AM
blacksoul
15
Oct 3, 2002 08:41 PM
M.A.R.C.
May 22, 2002 06:30 AM
