Killing the battery . . . maybe I'm missing something?
Old Jul 10, 2004 | 07:29 AM
AVATAR's Avatar
Default Killing the battery . . . maybe I'm missing something? *update*
Alright awhile back came out to my car to find that the battery was dead, so I bought a new battery . . . it worked fine for a week or so . . . then died (battery). So I thought "no problem the alternators bad" so I bought a new alternator and had the battery replaced again. Car drove fine for a week or longer again and now I'm back to square one. I've checked the connections, grounds, and fuses most most of the starting/charging system and it seems to check out okay. If anyone knows of stuff in peticular for me to look for or stuff I might have overlooked please help. I'm running out of patience and $. Car is a 2000 Si CR/VTEC with Hondata. Thanks
Modified by AVATAR at 4:47 PM 8/23/2004
Old Jul 10, 2004 | 07:31 AM
Mario.'s Avatar
Default Re: Killing the battery . . . maybe I'm missing something? (AVATAR)
Welcome to my ******* life man. I've been having the same damn problem as you are. Right now the car sorta drives (when gassing, the car charges... when I brake/idle it decharges) but not a week ago I had the same problem you have.
Old Jul 10, 2004 | 07:54 AM
AVATAR's Avatar
Default Re: Killing the battery . . . maybe I'm missing something? (Mario BA4)
that sucks I unfortunately am really lazy and havent even checked to make sure the alternator is charging the battery. Just hoping for a simple solution
Old Jul 10, 2004 | 08:26 AM
Mario.'s Avatar
Yea... I dunno what the hell. When I give the car gas, it charges. When I don't give it gas... it decharges pretty much. Pretty lame.
Old Jul 10, 2004 | 08:29 AM
honda_power69's Avatar
I'd start with the aftermarket electrical items. Anything at all: stereo, VAFC, Hondata, etc. Check where all these items are getting their power from...everything SHOULD be getting a (+) connection from a source that only closes the circuit with ignition switch turned to on...anything put directly to a full-time power source is going to drain the battery constantly.
Old Jul 10, 2004 | 08:44 AM
AVATAR's Avatar
Default Re: (honda_power69)
good call. I thought this was only happening after the Hondata install, but then I didnt know if I was just trying to find something to blame it on. I've heard of starting/charging problems with Hondata when the ELD wasnt disabled . . . I also might try that as soon as I can get to a hondata tuner Thanks
Old Jul 10, 2004 | 09:15 AM
Mario.'s Avatar
Default Re: (AVATAR)
FWIW, sorry for jacking your thread, here are video's of what is happening:
http://mariowc.no-ip.com/charging01.avi
http://mariowc.no-ip.com/charging02.avi
Old Jul 10, 2004 | 10:53 AM
AVATAR's Avatar
Default Re: (Mario BA4)
no problem, it kinda keeps my thread ttt I cant see the video.
Old Jul 10, 2004 | 11:26 AM
Mario.'s Avatar
It's a 20MB vid, kinda big, my camera wasn't designed for video, haha.
Old Jul 10, 2004 | 06:39 PM
suspendedHatch's Avatar
If your alternator or something kills your battery, fix the problem, then charge the battery. Don't waste the ******* battery, especially two fairly new ones. Get a cheap $20 multimeter and find the problem. Damn, 3 batteries = $180.
Old Jul 10, 2004 | 08:25 PM
GZERO's Avatar
Default Re: (shaundrake)
i think you have a consumption of power around your car, so when you leave the car for a while this consumption takes all the power away, now, you need a voltimeter/multimeter to check the voltage of the car at idle with everything off to see if the alternator is working properly, also, like somebody mentioned before, check for the aftermarket stuff to see if they are getting their power from where they should...etc..
Old Jul 10, 2004 | 09:23 PM
Mario.'s Avatar
Default Re: (GZERO)
I have spent $0 on this project - all it is swapping from my parts car.
I found out that not only was the alternator plug corroded, but the alternator IS dead. A friend of mine is upgrading to a 90amp tomorrow.. so I get his old one and he gets my broken one for a core return.
Old Jul 12, 2004 | 04:50 PM
AVATAR's Avatar
I think he was referring to me, to really 3 batteries doesnt = $180 it equals about $50 with a lifetime warranty. I'm gonna replace it again and chase it from their. We'll do an alternator test probably tomarrow after work and maybe a draw test. I'm just a lazy guy hoping for an easy solution
Old Jul 12, 2004 | 08:53 PM
Mario.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AVATAR &raquo;</TD></TR><TR><TD CLASS="quote">I think he was referring to me, to really 3 batteries doesnt = $180 it equals about $50 with a lifetime warranty. I'm gonna replace it again and chase it from their. We'll do an alternator test probably tomarrow after work and maybe a draw test. I'm just a lazy guy hoping for an easy solution </TD></TR></TABLE>
Oh. Doh, your thread, not mine.
Anyways, fixed my problem - both the plug and the alternator **** out on me. Cleaned the plug, spread the contacts, and new alternator ==
Old Aug 23, 2004 | 01:47 PM
AVATAR's Avatar
well since not alot of people usually posts the fixes to there problems I thought I would.
I wound up doing an alternator test and the one I had was junk. We cleaned up the battery ground and found that the ground on the tranny wasnt making a great contact and was arching all around the 10mm bolt. So we cleaned it up and tightened it down . . . havent had any charging problems since . . .
b20hondacivic
Feb 5, 2013 07:50 PM
Touek
Oct 21, 2011 03:20 AM
Integ-boy
Nov 26, 2007 06:12 PM
dude wheres my car
Audio / Security / Video
Jul 16, 2004 07:16 AM
Sonnboy18
Nov 5, 2003 03:35 AM
