keeping Auto Trans. w/B18 swap
Old Jan 11, 2011 | 02:22 PM
Pssst!'s Avatar
Default keeping Auto Trans. w/B18 swap
Hello HT. I tried searching but didnt find out exactly what is need to do a auto b18c or b18b into a 96 Civic 1.6L auto.
I'm guessing auto axles are needed from the B trans. but what about engine mounts and ecu? Wiring hopefully isnt a pain due to car is OBD2a, but not sure. I remember reading that some vehicles had seperate trans. and engine ecus.
Thanks for your help.
Old Jan 11, 2011 | 05:01 PM
tonythetuner®'s Avatar
Default Re: keeping Auto Trans. w/B18 swap
You can't do a auto b18c no ecu is automatic Vtec that I kno of.... and I don't think they sell a trany mount to use a auto b series tranny in a civic. So pretty much impossible unless you get a custom tranny mount made and run the b18b1 with auto ecu
Old Jan 11, 2011 | 05:36 PM
Pssst!'s Avatar
I thought the EG's and Ek's engine bay was the same as the DC2's, so the mounts are the same?
Old Jan 15, 2011 | 12:46 PM
Pssst!'s Avatar
Or are the automatics different?
Old Jan 15, 2011 | 07:45 PM
Blown90hatcH's Avatar
Incorrect. There is an Automatic OBD1 GSR swap that you can use in the OBD2a civic. The OBD1 auto P72 ecu uses all four plugs A, B, C and D and has all the auto functions in the ecu.
If you want to run the OBD1 automatic B18b swap, you will need to get the OBD1 automatic ecu and the TCM.
I sell both harnesses to run either setup in your car if you are interested.
NhocCuteGirls's Avatar
__________________
| BitDefender Total Security 2 Yrs 1 PC 2011 | Gantt Chart Library 4.0.0 | Modem Master ActiveX Component 1.2.7701 | Aloaha Crypt Disk 5.0.0 | Power Audio Video DVD Converter 3.2.30
Old Jan 18, 2011 | 09:41 PM
v8~killa's Avatar
ok bro anything is possible....dont listen to any of these dumb ****s...but bown90hatch....this person knows his ****....n sells harness for this type of setup...trust me when i say...BUY ONE FROM HIM! price shoudnt matter...i did an auto swap...and did my own harness..alot of reading wire diagrams..and made sure i didnt **** u....and let me tell you..mission bro....never again...anywho...need help...on all the mechanical probs...pm me n ill be happy to help..all the electrical just pm blown90hatch..ohhh and by the way i have a 96 del sol...LSvtec...!
Old Jan 20, 2011 | 06:40 AM
Pssst!'s Avatar
Thanks Bro
SPITVENOM67
Apr 5, 2012 06:10 AM
dwn2earth922
May 25, 2007 09:02 PM
usfsfirefighter0
Jan 6, 2005 11:25 AM
Spins
May 27, 2004 07:23 PM
MattsHatch93
Dec 22, 2002 02:50 PM
