K20 Engine Spec's.
Old Jul 21, 2003 | 01:02 PM
10K2HVN's Avatar
Default K20 Engine Spec's.
Well ive been looking for engine specs for the K20 motor.. All i could find on H-T was the Bore and the Stroke (86 x 86).. but find some new measurements that we could pass around now...
http://www.speedvisionwc.com/c...S.pdf
Bore: 86 mm
Stroke: 86 mm
Rod Length: 139 mm (C to C)
Deck Height: 212 mm
Rod Stroke Ratio: 1.6162 ~ 1.62 R/S
Compression Ratio: 9.8:1, 11:1, 11.5:1
edit: more of the same info
http://www.sportcompactcarweb....acura/
-"K20 is 22 lbs lighter then the B18C"
-"The K20 again uses an open-deck, die-cast aluminum block with cast-in iron cylinder liners, but at the bottom of the crankcase, where the B18 used a sturdy main bearing girdle for bottom-end strength, the K20 does one better, integrating the main bearing caps into a crankcase extension. This "split crankcase" design is becoming the standard for new engines, as it delivers noise, vibration and harshness benefits as well as improved strength."
Modified by 10K2HVN at 2:16 PM 7/21/2003
Old Jul 21, 2003 | 04:54 PM
10K2HVN's Avatar
Default Re: K20 Engine Spec's. (10K2HVN)
I was wondering if anyone has any pictures of the Engine?
Preferably, the Rotating Assembly. Inside the engine.
Head, Combustion Chambers would be nice too.
Thanks for anything.
-10k
Old Jul 25, 2003 | 04:31 AM
10K2HVN's Avatar
Jesus, i have to do this myself....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJ23FE &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jul 25, 2003 | 04:43 AM
10K2HVN's Avatar
im creating my own gallery...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edo &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Jul 25, 2003 | 12:06 PM
1fastVX's Avatar
Hey here is some more K20 info for ya with some good pics of the block
https://honda-tech.com/zerothread?id=563523
Old Jul 25, 2003 | 01:18 PM
EFb18b's Avatar
Default Re: K20 Engine Spec's. (1fastVX)
jesus man that is sweet!
hey you wouldn't happen to know how much a k20a2 head goes for do you?
Old Jul 25, 2003 | 01:21 PM
Kamin's Avatar
Default Re: K20 Engine Spec's. (Redlineracer)
is that a timing chain?!
lol
Old Jul 25, 2003 | 02:19 PM
10K2HVN's Avatar
WOW THATS JUST SWEEET!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I shot these pix of a K series block in the process of getting sleeves at Benson Machine. That is not a finish hone on the sleeves. Check the fit between the sleeves. Just beautiful. Note the full girdle. This is the future.
yeah, K20's come with heavy timimg chains now...
DAMN&lt;look at that crank/block girdle..!
Old Jul 25, 2003 | 05:11 PM
Katman's Avatar
here's the JDM DC5 bible I scanned back in '01...
http://www.ff-squad.com/mags/revspeed/rsx-bible/
Just some misc K-series info..
Not only does the K-series have a timing change but it uses a roller-rocker arm assembly unlike the B-series, which use roller-pads and in norcal speak is 'hella' dope. The motor also turns in the correct way, clockwise, rather than counter-clockwise ala B-series.
The K camshafts are interchangeable with the S2000/F20C engine....actually I think, the whole S2000 head assembly is intercheangeable with a K20-S/R series.
Old Jul 25, 2003 | 06:51 PM
10K2HVN's Avatar
Default Re: K20 Engine Spec's. (Katman)
wow..kewl...!
thanks Katman, and everyone.
Old Jul 26, 2003 | 03:08 AM
EFb18b's Avatar
Default Re: K20 Engine Spec's. (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">is that a timing chain?!
lol</TD></TR></TABLE>
yes the timing chain ownz all!!!
Old Jul 26, 2003 | 05:37 AM
DCStreetHtch's Avatar
that is freakin weird.... maybe just to me!!!??
and damn, that girdle is HUGE!
-Bryan-
Boost_allways
K Series
Aug 9, 2009 09:03 AM
ProPower Engines
Dec 23, 2008 03:43 PM
hondamark35
Jan 19, 2008 10:50 PM
HeikDiesel
Feb 19, 2005 07:58 PM
thawheelman
Mar 2, 2004 12:13 PM
